Amplify your Audio with TV Ones S2-101AA
The S2-101AA Stereo Audio Power Amplifier is the latest additional to TV One’s functional S2 Series. It provides for a wide range of audio input connections including RCA jacks, Mini-Combicon Terminal jacks and a 3.5mm single ended jack to accommodate PC audio inputs. The output connectors utilize spring loaded terminals for connection to external speakers. The S2-101AA has a Recommended Retail Price of £335 (€493) and is available now.
The S2-101AA provides 10 watts RMS per channel into a 4 ohm load when signals from a pre-amplified source are provided as inputs. It operates with very low Total Harmonic Distortion (THD+N), very high Signal to Noise Ratio (S/N+N) plus Crosstalk is greatly minimized. Frequency Response is a very wide 20Hz to 24kHz and the inputs can be either balanced or unbalanced. To prevent speaker damage, the unit has Pop Suppression upon turn on. It also features short circuit and over temperature protection.
Mechanical construction uses the same form factor as the companion S2 switcher products and the S2-101AA can be rack mounted using the optional RM-220 single/dual rack mount kit. The unit may be controlled by the front push buttons, the Downloadable Windows RS-232 Controller or through Infra-Red Support. The unit is powered by a +12VDC/4 Amp Power Supply.
The entire TV One product line can be viewed on website www.tvone.co.uk, alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
