Amphion Debuts Krypton3X 3-Way Flagship Loudspeaker: Munich High-End 2023
The Amphion Krypton3X floorstanding loudspeaker incorporates a new crossover and tweeter design that provides a better listening experience with lower distortion.
Amphion Krypton 3x Loudspeaker Pair Lifestyle in White
Finnish loudspeaker brand, Amphion, will be making the European debut of the updated Krypton3X at this month’s High-End Munich 2023 show (May 18 through 21, 2023).
Tip: For those attending the Munich show, the Krypton3X will be on display alongside Amphion’s Argon studio monitor lines — including the recently launched One25Ain Halle 3, booth M12/N05.
Krypton3X Overview
The goal of the Krypton line has been to provide a full range of concert hall-type listening experiences at home.
The Krypton3X is a full-range floorstanding passive speaker that is designed to deliver strong impact and nuance throughout its frequency range.
The Krypton3X brings a highly innovative update by incorporating a new state-of-the-art tweeter and low crossover point inside a unique cardioid cabinet design to minimize unwanted reflections, making any room fit to handle the updated speaker.
Amphion Krypton3X Loudspeaker White Angle
Tweeter Design
A new tweeter with a redesigned crossover allows the Krypton3X to achieve even better resolution and even clearer imaging than before. The 25mm titanium tweeter combines low distortion with high extension and seamlessly integrates with the midrange drivers to form a large driver combination. High-quality components were carefully selected for the new crossover to compliment the new tweeter in order to keep the similar sonic character and tone – but with improved sonics.
Amphion Krypton 3x Loudspeaker MTM Drivers
Midrange/Woofer Design
The Krypton3X incorporates a three-way MTM configuration  (midrange on top, tweeter in the middle, and second midrange below the tweeter). The proprietary papyrus 8” midrange/woofers and titanium tweeter use Amphion´s proprietary waveguide technology to create uniform time-accurate point source from 160Hz upwards.
The large midrange/woofer surface area is designed to provide smoothness, clarity, and high power handling with the lowest possible levels of distortion. The ribbed woofer driver provides impact, speed, and detail.
Amphion Krypton3X Loudspeaker Driver
A cardioid midrange combined with U/D/D (Uniformly Directive Diffusion) technology, minimizes unwanted reflections from side and back walls (up to 20dB). This allows the Krypton3X to perform well in small rooms or close to large windows. Both midrange drivers are encased in their own chambers which are side vented by holes drilled in the shape of an acute triangle.
For better full-range sound reproduction, the Krypton3X incorporates a 10” side-firing woofer. The rigid aluminum cone and long excursion ensure powerful, extended yet controlled bass.
Amphion Krypton3X Loudspeaker Lifestyle White
Speaker Placement Options
The Krypton3X speakers can be placed with the woofers facing inwards (preferred small room placement), or outwards (for a broader soundstage in a larger room). The woofer is mounted in the vented enclosure located between the midrange driver’s chambers and is hidden behind the cloth cover, which contributes to the understated aesthetics of the Krypton3X.
From Anssi Hyvönen, the Founder and Managing Director of Amphion Loudspeakers: “Krypton3X offers full-range sound in a room-friendly package. The combination of its new tweeter and the dual 8” midranges are intoxicatingly detailed and involving and perform superbly well even in challenging acoustic spaces…We are very proud to introduce the fifth version of our flagship speaker to our customers.
Amphion Krypton3x Loudspeaker Rear White
Specifications
  • Speaker Model: Krypton3X
  • Speaker Type: Three-way vented (Bass Reflex
  • Tweeter: 1 x 1” with a titanium driver
  • Mid-range: 2 x 8” with papyrus drivers
  • Woofer:  1 x 10” with aluminum driver
  • Crossover Points: 160Hz/1600Hz
  • Impedance: 4 ohms
  • Sensitivity: 89dB
  • Frequency response (+/- 3dB):  21 – 25,000 Hz
  • Recommended Amplifier Power: 100-300W
  • Dimensions:  1370 x 330 x 480 mm  (53.9 x 13 x 18.9-inches)
  • Weight: 70 kg/ 154 lbs
Tip: The Krypton3X is handmade in Finland.
Amphion Krypton3X Loudspeaker in Black, White, and Walnut Finishes
Availability and Pricing
The Amphion Krypton3X floorstanding speakers are available in standard white and black veneer for $12,000 per piece, while the Walnut costs $12,500.
Prices may vary due to local taxes, shipping, and other additional costs. Please find your local partner here.
Tip: US and Canada partners.
Epson QS100 UST Projector Front Lifestyle
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
In-depth review compares the Q Acoustics 5050 floorstanding loudspeakers ($1,999/pair) with three different amplifiers to reveal what makes them sing.
JBL recently released an updated version of its classic speaker with entirely new components and an updated internal design. Can the copy beat the...
A new audio brand named Oneiros teases a new high-end loudspeaker set to debut on December 5, 2024 at a private launch event in...
Priced from $600 to $2,200 per pair, KEF's most affordable loudspeaker range includes 8 models featuring 12th generation Uni-Q drivers.
The world's first headphones featuring DALI's patented Soft Magnetic Compound (SMC) technology. With 50mm custom drivers, active noise cancellation, aptX Adaptive Bluetooth and USB-C/3.5mm...
