Amazon Fire TV Stick 4K Select Isn’t What You Think: Cloud Streaming Yes, Dolby Atmos No
Amazon’s Fire TV Stick 4K Select offers Vega OS and cloud app streaming but lacks Dolby Vision, Dolby Atmos, and full app support, making it a mixed bag compared to the 4K and 4K Max.
Amazon Fire TV Stick 4K Select Accessories
Amazon already sells three Fire TV Stick models — the 4K Max, 4K, and HD — so when the company announced a fourth, the Fire TV Stick 4K Select, it raised some eyebrows. Do we really need another one? On paper, it looks like a budget-friendly version of the 4K, but then come the “wait, it doesn’t do what?” details: it supports 4K UHD and HDR10+, but skips Dolby Vision and Dolby Atmos entirely.
Amazon Fire TV Stick Select 2025
Vega OS: Amazon’s New Streaming Platform Behind the Fire TV Stick 4K Select
Unlike Amazon’s other Fire TV Sticks, the Fire TV Stick 4K Select runs on a brand-new operating system called Vega OS — not the familiar Android-based Fire OS found in Amazon’s existing streamers, TVs, and soundbars. Vega is Linux-based, marking a major shift in Amazon’s software strategy as the company plans to phase out Fire OS in future products.
Pro Tip: Amazon has reportedly been quietly testing Vega OS in select Echo devices as well.
While Vega OS supports the upcoming Alexa+ AI voice assistant, its current feature set remains a work in progress, with some inconsistencies compared to the tried-and-true Fire OS experience.
To start, Vega OS launches with a smaller app library than Fire OS. Amazon must rebuild or port every Fire TV app into a Vega-specific format, meaning many popular apps aren’t yet available — and some might never make the jump. This includes future Smart TVs from both Amazon and partner brands that will also run Vega OS.
Another major change is limited app sideloading. Fire OS allowed users to manually install apps via APK files, but Vega uses a new .vpkg format. That means only apps officially published to the Amazon Appstore and marked Vega-compatible can be downloaded and run on the Fire TV Stick 4K Select or any upcoming Vega-based device.
To make matters worse, reports indicate that Netflix and Disney+ won’t even be available for download at launch — though, as always with Amazon, there’s a twist coming.
fire-tv-stick-4k-select-box
Cloud Streaming: The Fire TV Stick 4K Select’s Surprising Power Move
It turns out the Fire TV Stick 4K Select can launch apps directly from the Cloud — no downloading or installation required. It works much like Cloud gaming, streaming the app interface and content in real time. If Amazon can make this work reliably, it could sidestep one of Vega OS’s biggest hurdles: the need to rebuild every app from scratch.
According to Amazon spokesperson Melanie Garvey, “Select developers will have their existing apps cloud-streamed while they develop a version of their app for Vega.” In other words, the Cloud could be Amazon’s bridge between the familiar Fire OS experience and its new Linux-based ecosystem.
Amazon Fire TV Sticks Comparison
Pro Tip: All Amazon Fire TV Sticks have the same visual look and similar dimensions and weight.
Amazon Fire TV Stick Model4K Select (2025)4K Max (2023)4K (2023)HD (2024)
Product TypeHDMI Plug-in Media StreamerHDMI Plug-in Media StreamerHDMI Plug-in Media StreamerHDMI Plug-in Media Streamer
Price$39.99$59.99$49.99$34.99
OSVega OSFire OSFire OSFire OS
ProcessorQuad-Core 1.7 GHzQuad-Core 2.0 GHzQuad-Core 1.7 GHzQuad-Core 1.7 GHz
GPUNot Indicated850 MHz650 MHzNot Indicated
Storage8 GB16 GB8 GB8 GB
WiFi5: Dual Band, Dual Antenna MIMO, 802.11 a/b/c/g/n/ac6E: Tri-Band, 802.11 a/b/c/g/n/ac/ax (2.4, 5, 6 GHz)6: Dual-Band, 802.11 a/b/c/g/n/ac/ax (2.4, 5 GHz)5: Dual Band, Dual Antenna MIMO, 802.11 a/b/c/g/n/ac
BluetoothVer 5.0:LEVer 5.2, BLEVer 5.2, BLEVer 5.0:LE
Voice SupportYes, with Alexa Voice Remote or Fire TV App (iOS, Android) Yes, with Alexa Voice Remote or Fire TV App (iOS, Android) Yes, with Alexa Voice Remote or Fire TV App (iOS, Android) Yes, with Alexa Voice Remote or Fire TV App (iOS, Android)
IR Device Control (with Alexa Voice Remote)YesYesYesYes
Cloud StorageFree for digital content purchased from Amazon Free for digital content purchased from Amazon Free for digital content purchased from Amazon Free for digital content purchased from Amazon
PortsHDMI for Audio/Video, micro USB for powerHDMI 2.1 for Audio/Video, ARC, micro USB for powerHDMI 2.1 for Audio/Video, ARC, micro USB for powerHDMI for Audio/Video, micro USB for power
Audio SupportHDMI pass-through of Dolby-encoded audio Dolby Atmos, 7.1 surround sound
2-channel, stereo
HDMI pass-through up to 5.1
2-channel, stereo
Photo SupportNot IndicatedJPEG, PNG, GIF, BMPJPEG, PNG, GIF, BMPNot Indicated
Input Resolution SupportUp to 4K UHDUp to 4K UHDUp to 4K UHDUp to 1080p
HDR SupportHDR10, HDR10+, HLGDolby Vision, HDR10, HDR10+, HLGDolby Vision, HDR10, HDR10+, HLGHDR10, HDR10+, HLG
Video Format SupportH.265, H.264, VP1, AV1H.265, H.264, VP1, AV1H.265, H.264, VP1, AV1H.265, H.264, VP1
Output Resolution SupportUp to 4K UHDUp to 4K UHDUp to 4K UHDUp to 1080p
System RequirementsAny TV with an available HDMI input, Hi-Speed InternetAny TV with an available HDMI input, Hi-Speed InternetAny TV with an available HDMI input, Hi-Speed InternetAny TV with an available HDMI input, Hi-Speed Internet
TV CompatibilityHDCP 2.2
4K UHD TVs with 24/25/30/50/60 Hz
1080p and 720p TVs with 50/60Hz
HDCP 2.2
HDCP 2.2
Warranty and Series1-Year (Extended Warranty Optional)1-Year (Extended Warranty Optional)1-Year (Extended Warranty Optional)1-Year (Extended Warranty Optional)
Content AvailabilityApps and Series are subject to change or withdrawal. Some apps may require a separate subscription paymentApps and Series are subject to change or withdrawal. Some apps may require a separate subscription paymentApps and Series are subject to change or withdrawal. Some apps may require a separate subscription paymentApps and Series are subject to change or withdrawal. Some apps may require a separate subscription payment
Accessibility FeaturesVoice View
Screen Magnifier
Text Banner
Closed Captions
Audio Description
Bluetooth Headphones
Voice View
Closed Captions
Audio Description
Bluetooth Headphone
Voice View
Closed Captions
Audio Description
Bluetooth Headphone
Voice View
Screen Magnifier
Text Banner
Closed Captions
Audio Description
Dimensions3.9 x 1.2 x .06 inches
99 x 30 x 14 mm
99 x 30 x 14 mm
99 x 30 x 14 mm
3.4 x 1.2 x 0.5 inches
86 x 30 x 13 mm
Weight 1.5 oz / 42 grams1.53 oz / 43.5 grams1.53 oz / 43.5 grams1.1 oz / 32.0 grams
Included in the BoxFire TV Stick 4K Select
Alexa Remote
2 AAA Batteries
Power Cable
Power Adapter
HDMI Extender Cable
Quick Setup Guide
Fire TV Stick 4K Max
Alexa Remote
2 AAA Batteries
Power Cable
Power Adapter
HDMI Extender Cable
Quick Setup Guide
Alexa Remote
2 AAA Batteries
Power Cable
Power Adapter
HDMI Extender Cable
Quick Setup Guide
Fire TV Stick HD
Alexa Remote
2 AAA Batteries
Power Cable
Power Adapter
HDMI Extender Cable
Quick Setup Guide
Software Security UpdatesYes – Up to 4 Years after the last available product availability dateYes – Up to 4 Years after the last available product availability dateYes – Up to 4 Years after the last available product availability dateYes – Up to 4 Years after the last available product availability date
Pro Tip: The Fire TV Stick 4K Select will soon support Alexa+Xbox Game Pass, Amazon Luna, and Amazon Kids+, expanding its functionality beyond the current app limitations.
Amazon Fire TV Stick 4K Select Setup
The Bottom Line
The Fire TV Stick 4K Select is Amazon’s bold, if messy, experiment with Vega OS. While the Linux-based platform promises more control, better performance, and cloud-based app access that could sidestep Vega’s limited app library, it comes with clear compromises. No Dolby Vision, no Dolby Atmos, and limited app sideloading make it feel like a half-step compared to the existing Fire TV 4K and 4K Max, which remain the smarter picks for most users. Vega is intriguing, and the cloud strategy has potential, but right now the 4K Select is a mixed bag — ambitious, yes, but not fully baked.
Price & Availability
1 Comment
1 Comment
  1. Freddie
    October 20, 2025 at 4:19 pm
    The Android apps that are streamed from the Amazon servers will only be free for 9 months and if an app for the VEGA operating system is not made, then Amazon will charge a monthly fee per active user and if the developer does not pay this fee, then the app will no longer be available. People will feel like they have been misled when the app is no longer available.
Burchardt S400 MKIII Bookshelf Loudspeaker Natural Oak Front 2026
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Audio Note Oto SE 35 Audio Note Oto SE 35
Audio Note ignores trends again. The Oto SE 35 brings new transformers and PSU to the cult EL84 amp. Low power, big attitude. Hear...
Magico S7 2026 Loudspeaker Views Magico S7 2026 Loudspeaker Views
Magico previews the $200,000 S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Emotiva BasX TA2+ Integrated Amplifier Emotiva BasX TA2+ Integrated Amplifier
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
I stream, you stream, here are our choices for the best video streaming devices of 2025.
TCL’s 2025 QM8K flagship TV offers near-OLED picture with CrystGlow WHVA Panel, Halo Control System, and Dolby Atmos—all starting at $2,299.99. A serious challenger...
TCL is putting Samsung, LG, and Hisense on notice with its featured packed TCL QM6K Series QD-MiniLED TVs (50 to 98 inches).
Panasonic Z8BA OLED delivers a 77-inch cinema-size picture, advanced HDR, True Game Mode, Dolby Atmos sound, and full Fire TV integration. But is it...
Streaming movie and TV shows is getting very complicated, and you may not always get what you think you're paying for.
TCL's first RGB MiniLED TV line will debut in China in 85-inch, 98-inch and 115-inch screen sizes. No word on U.S. availability.
Magnetar’s blu-ray disc players prove physical media isn’t dead with 4K UHD, hi-res audio, Roon Ready, and reference build quality that will take a...
