Amazon Fire HDX 8.9 Tablet (2014)
Amazon just announced an all-new Fire HDX 8.9 tablet starting at $379, which adds a more powerful processor for 70% faster graphics and Dolby Atmos for an improved headphone experience. Faster Wi-Fi with support for MIMO+HT80 has been added, but your router will need to be upgraded to experience better speeds. Finally, Fire OS 4 “Sangria” adds hundreds of new features and platform enhancements, including Firefly, ASAP, Smart Suspend, and other Amazon-exclusive features.
Interestingly, Amazon appears to have dropped Kindle from the its naming convention, while its older model keeps the moniker. The new, top-of-the-line, Fire HDX is the first tablet powered by the most advanced quad-core Snapdragon 805 processor, with each core running at up to 2.5 GHz. With the updated CPU and a 70% faster GPU than the previous generation Fire HDX, the all-new Fire HDX provides fast and fluid gaming and video.
With 30% more pixels than iPad’s Retina display, Amazon’s exclusive HDX 8.9-inch display combines exceptional pixel density (over 4 million pixels, 339 ppi) and perfect color accuracy (100% sRGB) resulting in the most lifelike images. The HDX display features Dynamic Light Control, which changes the white point of the display based on the ambient light of the surroundings in order to make the page of a Kindle book more closely resemble a piece of paper—this makes the best reading experience on a tablet even better on the new Fire HDX. Dynamic Light Control will be enabled starting later this year as part of a free, over-the-air software update.
Fire HDX is twice as loud as an iPad Air, delivering crisp, clear audio without distortion. The new Fire HDX is the first tablet with Dolby Atmos, which creates a new mobile headphone experience with multidimensional sound that flows above and around you. In a movie with Dolby Atmos, sound moves around you to match what you see on the screen—rain on a roof, airplanes taking off—so you’ll hear the sounds where they would be in real life.
Fire HDX is startlingly light, 20% lighter than iPad Air. Weighing just 13.2 ounces, Fire HDX’s frame is made of a single piece of machined magnesium with a blend of glass and nylon molded onto the unibody to create openings for the antennas and maximize signal strength without sacrificing weight or durability.
Even with a faster, more power-hungry processor, Fire HDX delivers incredible battery life—up to 12 hours of reading, surfing the web on Wi-Fi, watching videos, and listening to music—without adding weight or thickness to the design. The new Fire HDX also has weeks of standby battery life, so you don’t have to worry about waking up in the morning to find your tablet battery depleted because you forgot to plug it in. This standby battery life is made possible by combining power-efficient hardware components, low-level software improvements, and a new feature called Smart Suspend. Smart Suspend develops a device-specific profile for when the tablet is typically not in use and proactively turns wireless off and on to save power. Smart Suspend will still turn on Wi-Fi periodically to fetch new emails or app notifications, so when you pick up your tablet it’s ready to go and up to date.
Fire HDX supports the latest-generation wireless standard 802.11ac, which is capable of a peak bandwidth of 600Mbps, 4x the peak bandwidth of the previous generation Fire HDX.
Fire HDX’s microUSB port is used not only for charging, but also to connect Fire HDX to your other devices. With the Amazon HDMI and VGA adapters you can connect Fire HDX to your TV, a computer monitor, or projector. With the Amazon USB adapter you can connect USB flash drives, SD card readers, or a wired keyboard or mouse.
Price and Availability
Fire HDX 8.9 will be available October 21, 2014 from $379 to $494, but if you want 4G LTE from AT&T or Verizon add-on it will cost $100 more. Pre-orders accepted now.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Amazon introduces top-of-the-line Omni Series Mini-LED QLED 4K TVs in sizes from 55 to 85-inches at affordable price points.
At $249, the Amazon Fire TV Soundbar Plus features 3.1 channels, but is expandable to 5.1 with optional wireless subwoofer and speakers.
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
Bring function, style and entertainment to any educational experience with tech that kids will absolutely love.
Amazon just announced one of the most unique products of the year, called Echo. The tubular device is a wireless speaker and voice activated...
Impress Mom this year with the latest top-rated tech gifts this Mother's Day that are guaranteed to be useful all year long.
Car Audio
From Charlottlesville, Virginia in 1974, learn how Bill Crutchfield grew a tiny car stereo mail order business into a national electronics retailer.
Daily Deals
Looking for a truly massive 4K TV to enjoy the Super Bowl? Hisense is offering the brand new 100-inch U76N ULED TV for 60%...
