Aluminous Audio AL13.02 Speakers and SU13.01 Subwoofer
Aluminous Audio 13.02 Speakers
Aluminous Audio introduced high-priced stand-mounted speakers (AL13.02) and a subwoofer (SU13.01) constructed of aircraft-grade aluminum. The company claims their hand-made aluminum-cabinet sealed-alignment speakers effortlessly present recordings with utter clarity, openness and lack of distortion. The engaging, natural sound is illuminated from within, along with startling dynamics that deliver a profound musical experience.
Atomic Number 13
Aluminum carries atomic number 13 on the periodic table and it’s hundreds of times more rigid than any wood on earth, a logical low-resonance material for speaker cabinets. The Aluminous AL13.02 Monitors and SU13.01 Subwoofer are separated to take advantage of the inherent strength and rigidity of smaller structures so the cabinet has far less inherent sound of its own.
The Monitors and Subwoofer are sealed-cabinet designs making the system far easier to place. Aluminous speakers sound amazing even with less-than-perfect placement and almost as good from the next room!
The AL13.02 Monitor
The AL13.02 Monitors (pictured top) are available as stereo pairs or single speakers for surround in black or silver. When designing monitors you can choose between optimizing it for low-frequency response or transient response, one or the other. Since the AL13.01 Subwoofer handles low frequencies, the Monitor’s sealed-cabinet alignment allows the bass response to roll off gently resulting in far better focus and clarity throughout the frequency range. Aluminous Audio recommends solid-state amplifiers from 20W to 100W.
Aluminous Audio SU13.01 Subwoofers
The SU13.01 Subwoofer
The SU13.01 Subwoofer also takes advantage of the inherent strength of aluminum construction and the rigidity and damping of smaller structures. The crossover is variable from 30Hz to 120Hz and driven by an internal 175 watt class-D amplifier — no need for huge solid-state amplifiers to drive the Aluminous system.
Form Follows Function
Unlike overly-complicated speaker designs that introduce equally complex problems, form follows function in every Aluminous speaker. A music signal divided by crossovers into too many drivers just cannot reconstruct the signal without damaging its original form. Aluminous avoids this with perfectionist, minimalist double-decker, double-sided crossovers that bolt solidly to the interior cabinet. Aluminous feels the drivers should move, not the speaker or its constituent parts.
Price and Availability
  • AL13.02 Monitors (stand-mounted) Speakers → $15,000/pr
  • SU13.01 Subwoofer → $5,000/each
About Aluminous
Aluminous Audio speakers are hand-made in Spokane Valley, WA, following the vision and principles of creator Luke Zitterkopf. Using only aircraft-grade aluminum, costly drivers and hand-made crossovers, Aluminous fashions ultra-low-distortion speakers that free your music from the mechanics of playback. And because the monitors and subwoofer are separate they’re much easier to place wherever you listen to music.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
The Audioengine S6 Compact Subwoofer is their smallest, but a perfect match for your desktop home office audio system.
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new...
The REL Classic 99 subwoofer carries on the vintage design of the previously released Classic 98 but with a larger 12-inch driver and increased...
