Alta Audio Adam Three-way Floorstanding Loudspeaker
Tapping into over 30 years of loudspeaker design experience, the Alta Audio Adam is designed to deliver a more natural and dynamic sounding presentation.
Alta Audio Adam Loudspeakers in Rosewood Front Angle with and without grille
When it comes to speakers there is a lot to choose from, and often the best choice may not be from one of the major brands, but a smaller boutique manufacturer. Alta Audio, located in Huntington, NY, has been making well-received speakers that combine visually pleasing design with solid performance for over 30 years. One unique speaker entry from Alta is the Adam
Overview
The Alta Adam is a three-way floorstanding speaker that is designed to bring listeners a live-like performance.
Alta Audio Adam Loudspeakers in Rosewood Front and Back Angle
From Michael Levy, President, and CEO, of Alta Audio, LLC: “To my mind, speakers are music reproduction imaging instruments, meaning they should go so far as presenting an accurate representation of the recording without coloration or sonic anomalies…The Adam is the latest example of how we’re able to achieve that goal with a model that is notable for impeccable sound and stunning good looks.”
The Tweeter
The Alta Adam incorporates a 5.75” neodymium magnet ribbon tweeter. Alta feels this provides listeners with a more natural sounding and detailed high-frequency range.
The Midrange
To complement the innovative ribbon tweeter, the Adam includes a 6” wideband midrange driver. This driver is underhung which provides low distortion and ultra-fast transient response, while its aluminum pole increases dispersion.
The Woofer
Rounding out the driver package, Alta Audio provides the Adam with an 8.75” woofer.
The tuning parameters of this driver are coupled to Adam’s unique cabinet design for infrasonic (floor-moving) bass and refined cohesion between Adam’s XTL (Extended Transmission Line ) and its pure aluminum ribbon tweeter.
Alta Audio Adam Loudspeaker in Rosewood with grille Lifestyle
Tip: Extended Transmission Line is Alta Audio’s proprietary technology that applies sonic geometry for speaker cabinet tuning similar to the process of tuning a musical instrument. Alta believes that this delivers an accurate, fast, and powerful low-frequency response.
External Design
The Adam features an innovative cabinet design that is narrower at the top and slopes evenly to the wider bottom. This non-rectangular design approach further contributes to Adam’s ability to reproduce the detail, dimensionality, and feel of a live performance.
Alta Audio Loudspeaker Rear Terminal Closeup Rosewood
Specifications
  • Driver complement:
    • 1 x 5-3/4 inch ribbon tweeter
    • 1 x 6-inch midrange
    • 1 x 8-3/4 inch woofer
  • Sensitivity: 91.5 dB / 2.83 Volts @ 1Meter
  • Frequency Response: 20Hz to 47kHz
  • Crossover Points: 250Hz, 2.5kHz
  • Impedance: 4 Ohms
  • Power Handling: 50 to 300 Watts
  • Dimension and  Weight
    • Height: 41-inches
    • Width: 8.5 inches at the top, 15 inches at the bottom
    • Depth: 14 inches at the top, 18 inches at the bottom
    • Weight: 96 lbs
  • Alta XTL Bass with DampHard faceplate
  • Finishes Available: Piano Black, Beech, or Rosewood finish
Alta Audio Adam Loudspeakers in Black Front and Back Angle with and without grille
Pricing and Availability
The Alta Adam is priced at $17,000/pair (piano black) or $18,000/pair ( rosewood or beech) and is available through authorized Alta Audio Dealers.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
The Bowers & Wilkins 703 S3 is the least expensive floorstanding loudspeaker with a tweeter-on-top design in the 700 series.
In-depth review compares the Q Acoustics 5050 floorstanding loudspeakers ($1,999/pair) with three different amplifiers to reveal what makes them sing.
Priced from $600 to $2,200 per pair, KEF's most affordable loudspeaker range includes 8 models featuring 12th generation Uni-Q drivers.
The Q Acoustics 5000 Series featured new advanced drivers, stiffer bracing, and deliver improved clarity, speed, and detail at prices consumers can actually afford.
We've tested the Q Acoustics 5050 Floorstanding Loudspeakers with a range of equipment. Find out what works best.
