Alps Develops the Smallest FM Tuner
Alps Electric Developed TSM 1 Series as the Industry’s Smallest FM Tuner; Module Volume Production to Commence; First Tuner in Industry Under 6mm
TOKYO – Furthering the movement towards mobile devices that started with the mobile phone, Alps Electric (Pink Sheets:APELY) has developed the TSM 1 Series, an FM tuner module, and will start volume production in December this year.
From the introduction of the mobile phone, the growing multi-functionality of portable devices is increasingly remarkable in our times. For example, in addition to communications functions, the mobile phone can also show television programs; while the MP3 Player, in addition to playing and recording music, has a built-in radio function, all of which contribute to boosting the value of such multi-functional products.
Perceiving the need for these combined devices to be multi-functional, Alps has developed the industry’s smallest FM tuner module.
Realizing the industry’s smallest tuner module was made possible by Alps’ long-held commanding position in high frequency wave design technology and high-density mounting technology, which it placed at the service of the increasing demands of both miniaturization and multi-functionality.
Up until now, adding an FM function required an IC to be mounted on the circuit board in order to engineer the tuner separately and to carry out a performance inspection. Now, however, in this new product the tuner function is modularized, and an added shield cover increases tolerance from inside and outside. Together with being the industry’s smallest device, the TSM 1 Series increases freedom in set product design; and because the module function can be guaranteed, the performance inspection can be dispensed with, contributing to a shorter set design and production time.
What is more, because of Alps’ commanding position in high frequency wave design technology, the IC function could be removed and circuit loss reduced to achieve high-sensitivity with low distortion, resulting in stable reception and clear sound reproduction. In addition, the product’s low energy-consumption design principles enable prolonged use when supply is low. The TSM 1 Series is compatible with wave frequencies in Japan, Europe and the U.S.
Features
As volume production of the industry’s smallest FM tuner module is set to commence, Alps can boast the following accomplishments:
  1. Industry’s smallest size (internal area: 0.049 ml, total surface: 34.81 mm square)
  2. Modularized set construction contributes to shorter design and production times
  3. High sensitivity and low distortion
  4. Low energy costs
  5. Operable on frequencies in Europe, the U.S. and Japan
Principal Applications
For use in mobile telephones, various mobile information terminals, digital audio players, memory player, PCs, home audio-visual devices, etc.
Planned Sales
Start of volume production: December 2005
Sample price: 1,050 Yen
Monthly production: 500,000 units (January 2006)
Development: Communication Devices Division, Soma Plant (Fukushima prefecture)
Production location: Communication Devices Division, Soma Plant (Fukushima Prefecture)
Specifications
Product name TSM 1 Series
Dimensions 5.9 mm x 5.9 mm x 1.4 mm (W x D x H)
Receiving frequency range 76.0 – 108 MHz (FM, FM tuner attached)
Supply voltage 2.85 V
Current drain 8 mA (max. 12 mA)
Control signal Inter Integrated Circuit
External clock frequency 32.768 kHz (X’tal EXT)
DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
