Alpine Puts Sound System in a Cooler
PWD-CB1 Alpine In-Cooler Entertainment (ICE) system
Alpine just released the PWD-CB1 In-Cooler Entertainment (ICE) system. The mega-expensive portable sound system and premium cooler combo can truly turn any place into a party for $1500. Actual ice and beverages sold separately.
The PWD-CB1 Alpine ICE features a wireless sound system installed in a Grizzly Cooler and uses an innovative design that does not sacrifice storage capacity or cooling capability. The 180-watt Alpine sound system consists of a 2-way, 5.25-inch component waterproof speaker system with 4×10-inch bass radiators and a compact audio amplifier. The Bluetooth wireless connection provides audio streaming and pairs to a portable device in seconds through the illuminated control panel. The side-mounted 3.5-mm aux input is used for a wired connection to a portable device, while the 3.5-mm audio output links multiple PWD-CB1 Alpine ICE systems together for bigger sound. The PWD-CB1 Alpine ICE is powered by the included 16-foot cable that plugs into the vehicle’s 12 volt auxiliary power outlet. When the PWD-CB1 Alpine ICE is connected to the vehicle, the monitoring system on the control panel signals the user if the vehicle needs to be started to prevent the battery from completely discharging,
PWD-CB1 Alpine inside Jeep
The PWD-CB1 Alpine ICE upholds the distinctive Grizzly style while maintaining the sound performance of the Alpine system. The specially-designed speakers and bass radiators are recessed on the cooler’s front wall and produce balanced sound that can get loud when needed. The Alpine components are housed in an exclusive enclosure that protects them from interior cabin moisture but is only 3-inches deep, for minimal impact on the cooler’s 56-quart storage capacity.
The Alpine components are water resistant for easy cleanup, allowing the PWD-CB1 Alpine ICE to be used at outdoor activities like boating, fishing, water sports, camping and tailgating. The coated speaker grills are protected against corrosion, and rubber gaskets help keep water away from the control panel, speakers and electronics assemblies. A plastic cover and silicon rubber plugs shield the aux input and audio outputs when not in use. The PWD-CB1 Alpine ICE measures 34″ L x 16 ¾” W x 17 7/8″ H. Signature Grizzly features include molded-in heavy duty handles, BearClaw latching system, nylon rope handles with rubber grips, non-slip rubber feet, and a two-inch drain plug.
“For the past three years, we’ve produced Alpine Restyle vehicle-specific infotainment systems for the Jeep Wrangler, full-size trucks, and SUVs,” said Steve Crawford, vice president and general manager, aftermarket business unit, Alpine Electronics of America, Inc. “Through this experience, we recognized the need for an entertainment system that could be used outside of the vehicle yet matched the lifestyle activities of these owners, which led us to develop the PWD-CB1 Alpine ICE.”
Suggested Accessories
To take the PWD-CB1 Alpine ICE on the go, Alpine suggests connecting it to the Goal Zero Yeti 400 external battery (sold separately). Alpine also suggests the Mighty Max Plus One Sports Cart with all-terrain wheels (sold separately) as a compatible cart for transporting the PWD-CB1 Alpine ICE.
Price and Availability
The PWD-CB1 Alpine In-Cooler Entertainment (ICE) system is available for $1,500, visit www.alpine-usa.com/alpineice for a store locator and approved online retailers.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
