AdderLink X-DVI is a Breakthrough for Video Professionals
Adder, a leading developer of KVM switches, extenders and KVM over IP solutions, today announced the availability of the AdderLink X-DVI. The AdderLink X-DVI is the world’s first extender to send USB, DVI and DDC EDID signals over the same CAT6 cable. What’s more, Adder’s DVI KVM solutions will be delivered at a price comparable to current professional analogue extension solutions.
The X-DVI is ideal for users that require superior, no compromise video quality. Industries such as medical imaging, broadcasting, digital signage, graphic design, drafting and animation need to be confident that what is shown on screen is exactly what the workstation intends. The only real way to achieve this is via a digital medium such as DVI. The AdderLink X-DVI will support the extension of USB keyboards and mice and no compromise DVI over distances up to 165 ft.
Adder has broken down some serious technological barriers with this product. The X-DVI achieves full frequency clock rate for single link DVI connections which means you can extend any resolution within the single link DVI range. As an example, resolutions of 1920×1200 @ 60Hz can be achieved without the need to reduce data, frequency or color depth in any way. To achieve bidirectional USB communication alongside full no compromise DVI and all across a single CAT 6 cable is quite remarkable, and something no other manufacturer has been able to achieve. Delivering this kind of quality and functionality at a price point more reminiscent of analogue extension devices is certain to raise some eyebrows, but for Adder, it’s all about devising the best way possible to solve a problem.
A true plug and play solution, the AdderLink X-DVI feeds back extended profile DDC EDID information from the screen so that the video card is always set up perfectly. The AdderLink X-DVI is fully flash upgradeable; future proofing the product and protecting the customer’s hardware investment. Furthermore, the X-DVI can be interface powered at the computer end avoiding the need for additional power sockets and reducing cable clutter. For video only applications, an optional power supply can also be purchased.
The AdderLink X-DVI is available through local distribution partners around the world. Additional product information can be found at http://adder.us/products/AdderLink_X_DVI.aspx. The AdderLink X-DVI will carry a list price of $795 USD.
About Adder
Adder is a leading developer of KVM technology and extenders. Adder’s advanced range of KVM switches, extenders and IP solutions enable the control of local, remote and global IT systems. The company distributes its products in more than 60 countries through a network of distributors, resellers and OEMs. Adder has offices in the United States, United Kingdom, Germany, the Netherlands, and Singapore. Visit http://www.adder.com.
