DAPs
Preview: Astell&Kern’s Affordable P1 DAP Supports Bluetooth 5.3, DSD and 32-Bit PCM Playback
At $430, the P1 by Astell&Kern is a more affordable portable DAP for users with active lifestyles.
Astell&Kern ACTIVO P1 DAP
Only $430? If you are not familiar with the Korean manufacturer’s extensive lineup of award-winning DAPs that have ruled the category for years, the new P1 by Astell&Kern is decidedly more affordable. But will it make sense for those who already use their existing smartphone and a Dongle DAC?
Astell&Kern is considered by many the Rolls-Royce of DAPs (Digital Audio Players) and has enjoyed a lot of success with its high-end, yet pricey product line. However, its latest DAP hopes to unlock an entirely new market — users with an active lifestyle — at a lower price point.
Tip: The P1 by Astell&Kern will be sold as the ACTIVO P1 in other countries.
Astell&Kern ACTIVO P1 DAP Front and Back
P1 Features
Body Design: The P1 incorporates a combination of aluminum and polycarbonate to create a smooth curve for a comfortable grip. The aluminum body and audio module parts are divided into blocs to maximize contrast.
User Interface: The goal of the P1 is to provide optimal music playback, but if it isn’t easy to use, consumers won’t buy it. With that in mind, this DAP provides an easy user interface (UI) that includes a 4.1-inch HD touchscreen with triangles, circles, and squares.
The simplicity of the interface is your first clue that this is not aimed at the hardcore Head-Fi enthusiast, but those looking to try their first DAP with their existing pair of IEMS or headphones.
Astell&Kern ACTIVO P1 DAP Controls
Physical Controls: To further complement the UI, buttons are provided on the sides of the player. They are shaped so that users can tell the difference between each button by touch which allows easy control of the P1 while in a pocket or bag.
Three keys (play/pause, next, and previous) are combined, allowing users to easily control the player while viewing the display.
Compact Size: In addition to attractive design and easy control, the P1 has a compact, one-handed design.
This allows users to listen to lossless music experience while working out at the gym, running, walking around the neighborhood, or commuting.
Astell&Kern ACTIVO P1 DAP in-hand
Hi-Res Audio: Tuned by the audio experts at Astell&Kern, the P1 incorporates audio playback from a wide variety of music formats, including high-resolution audio up to 32-bit/384kHz PCM and DSD256.
DAC: The P1 features two ESS ES9219Q SABRE DACs in a dual-mono configuration, providing a dedicated DAC chip to the right and left channels. The dual-DAC structure creates a balanced circuit to deliver sound that is true to the original source.
Amplification: The P1 has a dedicated AMP circuit, based on Astell&Kern’s TERATON ALPHA. The TERATON ALPHA AMP ensures sound clarity, detail, and broad spatial resonance with its design technology.
Astell&Kern ACTIVO TERATON
Wireless Connectivity: Dual-band Wi-Fi and Google Play Store support allow users to download and install the most popular music streaming apps and easily stream their favorite music. Bluetooth 5.3 adds wireless support for 24-bit wireless playback using LDAC or aptX HD, PD 3.0 is supported for fast charging,
Storage Options: With 64GB of internal memory and support for microSD cards up to 1.5TB, you have plenty of space to store music you own or download tracks from streaming services to listen to in offline mode.
USB: USB DAC mode allows the P1 to be used as a premium DAC when connected to a Mac or Windows computer. A variety of options are available in USB DAC mode including the display of sample rate information for music currently playing.
EQ and Filters: The P1’s parametric equalizer options separate frequency ranges into 20 bands, and gain is adjustable by 0.01dB increments for precise and accurate control.
Users can also control the Q value to set the precise frequency range they like.  Seven DAC filter options allow listeners to further customize the sound profile.
Additional features of the P1 by Astell&Kern include:
  • MQA decoding, CrossFeed, and Roon Ready support (pending completion of testing and certification by Roon Labs).
Bonus: Preloaded into internal memory are three sample tracks from NativeDSD that showcase native DSD playback on the P1.
Also included in the box is a coupon to purchase additional music from NativeDSD at a discount.
P1 vs. A&Norma SR25
Astell&Kern ACTIVO P1 DAP (left) vs A&Norma SR25 DAP (right)
P1 (left) vs A&Norma SR25 DAP (right)
The following chart is a feature/specifications comparison of the P1 with an entry-level model in Astell&Kern’s current DAP line-up, the A&Norma SR25.
P1A&Norma SR25
Price$430$699
Body ColorWhisper WhiteMoon Silver, Onyx Black
Body MaterialAluminum, PolycarbonateAluminum
Display4.1-inch WVGA
(720 x 1280)
Touch Screen
3.6-inch WVGA
(720 x 1280)
TFT LCD
Supported Audio FormatsWAV, FLAC, WMA, MP3, OGG, APE, AAC, ALAC, AIFF, DFF, DSF, MQAWAV, FLAC, WMA, MP3, OGG, APE, AAC, ALAC, AIFF, DFF, DSF, MQA
PCM8kHz ~ 384kHz (8/16/24/32bits per Sample) 8kHz ~ 384kHz (8/16/24/32 bits per Sample)
DSD NativeDSD64 (1bit 2.8MHz), Stereo
DSD128 (1bit 5.6MHz), Stereo
DSD256 (1bit 11.2MHz), Stereo
Output LevelUnbalanced 2.0Vrms
Balanced 4.2Vrms
(Condition No Load)
Unbalance 2.0Vrms
Balance 4.0Vrms
(Condition No Load)
CPUOcta-CoreQuad-Core
DAC2 x ESS ES9219Q2 x Cirrus Logic CS43198
Audio DecodingSupport up to 32-bit / 384kHz Bit to Bit playbackSupport up to 32-bit / 384kHz Bit to Bit playback
Wired InputUSB Type-C input (for charging & PC & MAC data transfer)USB Type-C input (for charging & PC & MAC data transfer)
OutputsUnbalanced Out (3.5mm)
Balanced Out (4.4mm, only 5-pole supported)
Balanced Out (2.5mm, only 4-pole supported)
Wi-Fi802.11 a/b/g/n/ac (2.4/5GHz)802.11 b/g/n (2.4GHz)
BluetoothVer 5.3 with A2DP, AVRCP, Qualcomm aptx HD, LDAC, LHDC, AAC, SBCVer 4.2 with A2DP, AVRCP, Qualcomm aptX HD, LDAC
Frequency Response±0.013dB (Condition: 20Hz~20kHz)
Unbalanced
±0.013dB (Condition: 20Hz~20kHz) Balanced
±0.024dB (Condition: 20Hz~70kHz) Unbalanced
±0.022dB (Condition: 20Hz~70kHz) Balanced
±0.014dB (Condition: 20Hz~20kHz) Unbalanced
±0.011dB (Condition: 20Hz~20kHz) Balanced
±0.10dB (Condition: 20Hz~70kHz) Unbalanced
±0.12dB (Condition: 20Hz~70kHz) Balanced
S/N120dB @ 1kHz, Unbalanced
121dB @ 1kHz, Balanced
122dB @ 1kHz, Unbalanced
123dB @ 1kHz, Balanced
Crosstalk-139dB @ 1kHz, Unbalanced
-140dB @ 1kHz, Balanced
-138dB @ 1kHz, Unbalanced
-144dB @ 1kHz, Balanced
THD+N0.0006% @ 1kHz, Unbalanced
0.0007% @ 1kHz, Balanced
0.0007% @ 1kHz, Unbalanced
0.0008% @ 1kHz, Balanced
IMD SMPTE0.0002% Unbalanced
0.0003% Balanced
800Hz 10kHz (4:1)
0.0004% Unbalanced
0.0003% Balanced
800Hz 10kHz (4:1)
Output Impedance3.5mm (1 ohm)
4.4mm (2 ohm)
3.5mm (1.8 ohm)
2.5mm (1.6 ohm)
Clock Jitter (typical)25ps25ps
Built-in Memory64GB [NAND]64GB [NAND]
External MemorymicroSD x1
(Max. 1.5TB)
microSD x1
(Max. 1TB)
Battery Capacity2,700mAh 3.8V Li-Polymer3,150mAh 3.7V Li-Polymer Battery
Charge TimeAbout 1.5 hours (PD3.0 Charging)About 2.5 hours (Standard – 5V/2A Charging)
Playback TimeAbout 20 hours
(Standard: FLAC, 16-bit/44.1kHz, Vol.50, LCD Off)
About 21 hours
(Standard:: FLAC, 16-bit/44.1kHz, Unbalance, Volume 50, EQ OFF, LCD OFF)
Supported OSWindows 8,10,11(32/64bit) MAC OS X 10.7 and upWindows 7,8,10 (32/64bit), MAC OS X 10.7 and up
Dimensions (WHD)2.44” x 4.69” x 0.67”
(62 x 119.2 x 17.2 mm)
2.5” x 4.26” x 0.63”
(63.5 x 108.3 x 16.1 mm)
Weight5.46 oz
(155 g)
6.27 oz
(178 g)
Astell&Kern ACTIVO P1 DAP with IEM
Initial Impressions
There is no question that the P1 by Astell&Kern offers a lot of capabilities and performance potential at its asking price. If the sonic performance matches anything in the same price range from FiiO or Cayin — this might be a very competitive DAP at the bottom of the market.
In addition to its new design, the P1 offers a lot of great features found on previous models but at a much lower price than A&K’s next lowest priced DAP, the SR25.
On the negative side, as an active lifestyle product, there is no mention of an IP rating that would inform consumers how the P1 would hold up against the outdoor elements.
But we have to ask the most pressing question — is the person shopping for a $430 DAP likely to carry this around all day, in addition to the smartphone in their pocket that might be connected to a Dongle DAC?
Based on our extensive experience with Astell&Kern’s DAPs over the past decade, we suspect that the P1 offers superior sonic performance with the types of IEMs and headphones that a prospective buyer might own — but we wonder how it will hold up with larger dynamic and planar designs.
Does it make sense to stick with your existing smartphone and add a $200 to $300 Dongle DAC instead?
Not using your smartphone to stream will certainly save battery life and there is the added benefit of balanced outputs and digital inputs for those who may want to use more demanding headphones and/or connect the DAP to your laptop or desktop computer and use it as a hi-resolution DAC.
Price & Availability
The P1 by Astell&Kern will be available for $430 at Amazon beginning sometime in August 2024.
Related Reading
1 Comment
1 Comment
  1. ORT
    August 4, 2024 at 11:50 pm
    Hmmmmmmmm…I don’t know that I would call having “MQA” and being (nearly) RomperRoonReady® advantages, but…Nah. Those are not advantages. Verily, they are, wait for it…sAdvantages®!
    I am quite ancient and as such qualify to be called an ORT of little brain. I would give serious consideration to a DAP that could take all my “Mystery Music” and actually label said errors on my part with the correct Arteest, Title and Album Art. WTI®?! fArtificial® Intelligence can’t do that yet?! Again, I cry with bitten thumb, WTI®?!
    Roon couldna’ do it and I gave it two months before deleting it and setting out on a ORTwellian Hejira of sorts to make spur of Roonatics®. JRiver couldna’ do it. MusicBee couldna’ do it. I don’t want to do it. Talk about tedious tasks! fApple® (that portmanteau simply cracks me up!) Music couldna’ do it.
    Mayhap FiiO will (French HOCKEY reference ALERT!) turn the “Tromper du Chapeau” and deliver the goods in an affordable DAP that can doooooo it!
    Help him! He spoke FRENCH!! 😉
    Wouldn’t THAT be loverly? Yes, Liza. It would.
    ORTson Welles
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
DAPs
At $2,299, Astell&Kern found a few ways to maintain flagship audiophile DAP performance at a lower cost. Find out what's changed.
Ask an Expert
Waterproof vs. water resistant? Here's what the numbers really mean in those IP ratings.
The Astell&Kern A&ultima SP3000T was the only portable DAP that impressed us this year, but it will cost you $2,999 USD.
Play tapes on-the-go with FiiO's $99 transparent portable audio cassette player with USB-C charging and 13 hour battery life.
DAPs
At $2,999, Astell&Kerns's A&Ultima SP3000T DAP offers a triple amp system with tubes that are easy to get used to.
Bring function, style and entertainment to any educational experience with tech that kids will absolutely love.
DAPs
Does the new Astell&Kern A&ultima SP3000 DAP reclaim the Iron Throne? We can think of 3,699 reasons why that is true.
