Acoustic Energy AE1 Mk III SE Bookshelf Speakers Announced
Acoustic Energy Debuts Limited Edition AE1 Mk III SE – Available in Three Pristine Finishes and Strictly Limited to 100 Numbered Pairs
Acoustic Energy, an award-winning U.K.-based designer and manufacturer of audiophile-grade loudspeakers, is making available a limited, 100-pair numbered run of AE1 Mk III SE bookshelf speakers, based on the company’s classic AE1 model.
In addition to updated technologies and materials, the AE1 Mk III SE is available in four custom finishes — eight-layer Piano Black, Cheery Wood Veneer, Pearl White, and Bespoke Finishes, the latter of which can be painted to suit a customer’s preferences.
“The original AE1 continues to be one of our strongest sellers and, frankly, one of our greatest sources of pride,” commented Moses Gabbay, Acoustic Energy’s CEO/President. “After 20 years, we are excited to offer this limited edition to audiophiles who appreciate the best, because they are the ones who have supported Acoustic Energy since the very beginning.”
The AE1 Mk III SE represents an enhancement of the acclaimed original, with updated technology and materials that continue Acoustic Energy’s tradition of featuring only the most advanced ingredients in its speaker line. Designed and built in the U.K., the AE1 Mk III incorporates a heavily braced 18mm MDF cabinet that is lined with a 4mm steel plate using specially manufactured damping glue, resulting in a stiff, well-dampened enclosure.
The bass driver couples AE’s signature pressed alloy cone with critical hyperbolic flare, plus a die-cast magnesium allow chassis that boasts the ultimate in strength and rigidity. The motor assembly uses twin neodymium magnets and a 32mm voice-coil for enhanced speed and power handling. When coupled with the 38mm ring-radiator tweeter — featuring a frequency response out to over 40kHz — the result is the lowest possible distortion throughout its operating range.
The AE1 crossover was re-designed for the AE1 Mk III SE, with a “less is more” philosophy leading to a reduced number of components — six, as opposed to the usual 13. This move allowed the company’s engineers to test, audition and specify the best currently available ingredients, include a unique blend of ferrite-core and air-core inductors, Welwyn wire wound resistors, and ClarityCap capacitors. Internal wiring is all PTFE-coated multi-strand silver cable, terminated in a single pair of gold-plated WBT binding posts.
Each of the strictly limited run of 100 fully matched pairs is supplied with frequency response certificates and soft-touch gloves for handling. The suggested retail price is $5,000 per pair.
For further information about Acoustic Energy and its products, please contact Adam Sohmer, 718-499-9161, adam@sohmerassoc.com, or visit the company’s web site at www.acoustic-energy.co.uk.
In the U.S., Acoustic Energy is located at 675 VFW Parkway, #102, Chestnut Hill, MA 02467. The company may be reached at 508-695-8090.
Product Specifications
  • Bass/Mid Driver: 110mm spun aluminium cone
  • Tweeter: 38mm ring radiator
  • Crossover: Symmetrical third order at 3kHz
  • Frequency response: 70Hz — 22kHz @ +/-3dB
  • Power handling: Amplifiers rated up to 200Watts into 8 Ohms
  • Sensitivity: 87db for 2.83V at 1m
  • Nominal impedance: 8 Ohms
  • Total harmonic Distortion: Less than 0.3% 200Hz to 20kHz
  • Dimensions (H x W x D): 295 x 180 x 255mm
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
