Acoustic Energy AE100 Series MK2 Loudspeakers Get a Major Facelift
The Acoustic Energy 100 Series has been reborn with 5 new models that feature new drivers, cabinet construction and affordable pricing.
Acoustic Energy AE100 Series 2 Loudspeakers Group 2022
Acoustic Energy doesn’t get a lot of attention from the North American press (minus us) and that’s a huge loss for consumers. The British loudspeaker manufacturer has been around for decades and having survived more than a few ownership changes, the brand is back in proper hands. The AE1 Active Loudspeaker is one of the best available and I’ve covered it extensively over the past year.
The $1,500 asking price is incredibly reasonable but not everyone wants an active loudspeaker. Sitting just below the AE1 is the brand new Acoustic Energy 100 Series and if they are a genuine upgrade over the existing models — you really want to put these on your audition list for 2022 if your budget is below $1,000.
The new 100 Series, available from today through selected authorized dealers throughout the UK, isn’t just an upgrade, it’s a completely new design from the ground up. The U.S. market will see them in Q1 2022 according to our sources.
The design brief was to try and maintain the compact dimensions and sleek appearance of the previous 100 Series but offer a more mature, refined and bigger sound with greater bandwidth and power.
So, what’s changed?
Acoustic Energy AE100 Bookshelf Speaker in Walnut
Acoustic Energy AE100² (shown in walnut; also available in black and white)
First in line for an upgrade was the main drive unit; the 4” paper cone used for over a decade has performed admirably but Acoustic Energy extracted all the performance they could from it. Therefore the decision was made to move up to a 5” driver – this time utilising a 4 layer voice coil with flux rings to enable the dynamics, headroom and clarity demanded from the series design engineers.
This of course created a new problem of size and keeping those compact dimensions. Enter HDF (High Density Fibreboard). The engineers came to the conclusion they needed more internal volume to achieve maximum benefit from the new 5” driver. After much calculation and experimentation, the decision was made to move to HDF – unheard of at this price-point and usually limited to the very high-end.
HDF provides the option of using thinner cabinet walls with no loss in acoustic performance, the mass and stiffness of the 15mm HDF being the same as the previous 18mm MDF.
The result of this move is a small 15% increase in cabinet size but a 30% increase in internal volume gained over the previous 100 Series speakers.
The final piece of the puzzle was retaining the integration and musically rewarding character the slimline 100 Series cabinets benefitted from.
For this, a new 25mm soft-dome tweeter and waveguide was developed to perfectly match the new bass driver… taking a leaf out of the 500 Series book and pushing them as close together as physically possible thanks to a cutaway trim.
Aesthetically the new 100 Series retains similar lines to the older generation but cleaner and more refined. Cabinet veneer finishes have also been improved along with a dedicated flared trim on the bass port and higher-grade binding posts.
MD and Chief Design Engineer Mat Spandl commented “We knew the previous 100 Series was going to be a hard act to follow so we had to do something special and rewrote the design book for loudspeakers at this price. The result is a compact, slimline budget speaker range that we believe will raise the bar again and be unparalleled at the price.”
The new 100 Series (MK2) will retail from £229 to £599 and comprise of the AE100² bookshelf, AE109² floorstander, AE107² centre and AE108² active subwoofer… with a new AE120² MK2 flagship tower loudspeaker following in Spring 2022.
All speakers are available in Black and Walnut vinyl veneer with the AE1002 also available in White.
AE100²
Acoustic Energy AE109 and AE120 Floorstanding Loudspeakers in White, Black and Walnut
Acoustic Energy AE100² (shown in white; also available in black and walnut)
The AE100² (MK2) is a compact standmount/bookshelf loudspeaker that exhibits qualities which perfectly embody those of Acoustic Energy.
The AE100² has been designed with a view to achieving high sound pressure levels from a small enclosure. This is obtained principally through the use of a 130mm mid-bass drive unit built around an ultra-high force, long throw motor system. Bass performance is augmented by a slot shaped duct allowing for a considerable cross-sectional area while negating the issues of air turbulence.
Acoustic Energy AE100 2 Bookshlef Speakers Rear in Black and Walnut
A 25mm soft dome tweeter featuring Wide Dispersion Technology completes the driver compliment and is housed within a 15mm HDF cabinet. Taking design cues from the award-winning 500 Series and finished in a choice of satin white, black or walnut vinyl veneer finishes. The AE100² is sure to look good placed on speaker stands or bookshelves, while delivering a sound that belies its compact size.
Acoustic Energy AE109 and AE120 Floorstanding Loudspeakers in Black and Walnut
Acoustic Energy AE109² (left) and AE120² (right) Floorstanding Loudspeakers (both available in black or walnut)
AE109²
The AE109² (MK2) is designed to offer effortless, room filling performance from a slimline floor-standing loudspeaker in much the same way the world acclaimed original AE109 did 20 years ago. To do this, two 130mm paper drivers utilising an ultra-high force motor system are used in partnership with a 25mm soft dome tweeter. The 2.5-way crossover features a unique topology allowing integration and power handling previously un-achievable from this type of speaker. Particular attention has been paid to the phase and time alignment for the most cohesive performance possible.
Like the AE100² stand-mount speaker, the driver and crossover are housed within a substantial 15mm HDF cabinet that takes styling cues from the award winning 500 Series. The result is an audio product with clean and uncluttered lines that can still deliver the thrilling and powerful presentation Acoustic Energy owners have come to expect. Satin black and walnut vinyl veneer finishes are available.
AE120²
Acoustic Energy AE120 Floorstanding Loudspeakers in Black
Acoustic Energy AE120² in black (also available in walnut)
As the flagship of the range, the AE120² (MK2) is the largest model in the 100 series and a true 3-way design. This speaker offers a big sound from a slimline enclosure, tastefully styled to blend into a wide range of domestic environments.
Twin bass drive units underpin the room filling performance with a dedicated mid-range driver housed in its own enclosure, carefully designed to mitigate the harmful effects of rear wave reflections.
Integrated within the perfectly matched Wide Dispersion Technology (WDT) waveguide, Acoustic Energy’s 25mm soft dome tweeter manages the high frequencies with controlled dispersion, high sensitivity and low distortion.
The 3-way crossover is impedance compensated to avoid the resonance issues which would otherwise slow bass delivery and colour mid-range performance. Particular attention has also been paid to the phase and time alignment for optimum integration and soundstage.
The result is a loudspeaker offering smooth, wide dispersion high frequencies with a clean mid-range and lightning fast bass. The inert cabinet enclosure is constructed from 15mm HDF and like it’s smaller AE109² brother, supplied mass loaded to help dampen cabinet vibrations.
The internal bracing system has been carefully tuned to reduce cabinet resonances and mid-range colouration, whilst the new AE120²benefits from a subtlety styled, discrete satin black plinth to aide stability, further improving dynamics and stereo focus.
AE107²
Acoustic Energy AE107 2 Center Speaker in Walnut
Acoustic Energy AE107² Center Speaker in walnut (also available in black)
For home theater and multi-channel music systems, the AE107² (MK2) is a 2-way horizontal mount loudspeaker designed for centre channel applications. The AE107² delivers exceptional articulation and detail throughout the vocal range, augmented by powerful bass performance from the reflex loaded rear slot port. The compact center speaker can be placed within a cabinet or on a shelf.
AE108²
Acoustic Energy AE108 2 Subwoofer in Walnut
Acoustic Energy AE108² Subwoofer in walnut (also available in black)
The AE108² (MK2) is a new, compact, yet extremely powerful active subwoofer. Designed to work seamlessly as part of a multi-channel system including the AE100²s, AE109²s, AE120²s and AE107², the AE108² is ideal for the modern home where controlled bass performance is required without compromising the living space.
At less than one cubic foot in size, the AE108² can be positioned discretely. Finished in a choice of satin black or walnut vinyl veneer finishes, the AE108² delivers a bass punch that belies its compact size.
Specifications
AE100²AE109²AE120²AE107²AE108²
TypeBookshelfFloorstanderFloorstanderCenterSubwoofer
Design2-way2.5-way3-way2-waySealed Box
Drive Unit130mm paper cone130mm paper cones130mm paper cones130mm paper cones250mm high-excursion doped and stiffened paper cone
Tweeter25mm fabric dome25mm fabric dome25mm fabric dome25mm fabric dome
Frequency Range51Hz – 26kHz41Hz – 26kHz39Hz – 26kHz55Hz – 26kHz30Hz – 110Hz
Sensitivity87dB89dB90dB89dB
Peak SPL112dB115dB116dB115dB108dB
Power Handling120w175w200w175w150w
Crossover Frequency2.9kHz275Hz, 2.5kHz300Hz, 2.7kHz2.2kHz40 – 110Hz adjustable
Impedance6ohms6ohms6ohms6ohms
GrillesSlim, cloth magnetic fitSlim, cloth magnetic fitSlim, cloth magnetic fitSlim, cloth magnetic fit
Dimensions (HxWxD) (mm)290 x 165 x 250 860 x 165 x 250950 x 165 x 250 (inc. plinth)175 x 380 x 250290mm³
Weight:9.2kg (pair)16kg (each)19kg (each)4.6kg (each)8kg (each)
Finishes:Satin Black, Satin White and Walnut vinyl veneerSatin Black and Walnut vinyl veneerSatin Black and Walnut vinyl veneerSatin Black and Walnut vinyl veneerSatin Black and Walnut vinyl veneer
For more information: Acoustic Energy 100 Series
4 Comments
4 Comments
  1. Steve Fink
    January 5, 2022 at 10:38 pm
    Any idea on US pricing of AE100² spkrs ?
    • Ian White
      January 5, 2022 at 11:01 pm
      Steve,
      I reached out to AE and I suspect they will be around $500.
      Ian White
    • Bob Rapoport
      July 11, 2022 at 3:32 pm
      Hi Steve,
      I’m the longest serving AE dealer in the USA, the selling price of the AE100 Mk2 is $399 a pair including free shipping. At this price, you cant do better. You can order them at my site, all finishes in stock.
      https://www.essenceelectrostatic.com/product/ae-100-mk2-bookshelf/
  2. Steve Messenger
    October 30, 2022 at 5:28 am
    Hello Ian, I sure appreciate your reviews, and thank you for concentrating on high performing gear with good value that is on the more affordable end of the spectrum. Do you have other integrated amps to suggest for these speakers. Thank you. Steve
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Can an innovative 17-year old speaker designer with a familiar last name breathe new life into the jaded audiophile loudspeaker industry?
