Acer K330 LED DLP Projector
Acer introduced the portable K330 LED projector, its first with 500 ANSI lumens of brightness for projecting vivid, clear images. The new Acer K330 projector also marries portability with excellent image output; it weighs less than three pounds, and provides an HD-ready 1280×800 (WXGA) resolution with enhanced color saturation for brilliant color and clarity.
Customers will appreciate that the Acer K330 projector is packed with the latest technology, including an LED that provides 500 ANSI lumens of brightness, and a 4000:1 contrast ratio that results in crisp visuals. The Acer K330 ensures image accuracy with improved color saturation (60 to 130 percent NTSC) and Acer ColorSafe II technology. As a result, the Acer K330 projects these high-quality images in a wide range of natural, deep colors, making it the ideal projector for presentations and data, as well as digital entertainment including movies and photos.
Users making customer presentations with the Acer K330 can leave their notebook PC back at the office. Using the Acer K330's “Presentations to Go” function, customers can use the SD card reader or USB 2.0 port to display high-quality videos, audio as well as standard office files and presentations from an SD card or USB drive, eliminating the need to carry a computer at all times.
The new Acer K330 projector is ideal for consumers as well as businesses and educational institutions that need an advanced projector that can easily be moved around the home or office. It weighs only 2.73 pounds and measures 8.6-inches (W) by 6.6-inches (D) by 1.8-inches (H).
The Acer K330 LED projector is an excellent investment thanks to its many features and extended lifespan, which translate into significant cost savings for customers. Maintenance is reduced for the product since there is no lamp to replace. Plus, the long 20,000-hour LED life ensures long-term dependable projector use. In addition, the LED light turns on and off instantly and uses less power.
Its native WXGA resolution of 1280×800 and 16:10 aspect ratio can be adjusted to support a maximum 1080p (1920×1080) resolution and changed to either a 4:3 or 16:9 aspect ratio for video content from Blu-ray Discs, DVDs and other sources. It provides 24p Film Support and can project an image ranging in size from 30 to 100 inches diagonally from 2.5 to 8.3 feet away, so it's ideal both for a home environment as well as conference rooms and board rooms.
The Acer K330 is ready to connect to a range of sources. The HDMI port can be connected to popular sources like Blu-ray and DVD for full audio and video playback. It also provides standard connections through its analog RGB/component video (D-sub) and composite video/audio (4-pin mini jack) connections. These multiple connectors allow multiple PCs to be connected for fast switching between presentations.
The Acer K330 takes advantage of the latest technologies. When paired with a computer supporting 120Hz output and 3D software along with 3D glasses, the Acer K330 can project 3D content to give entertainment an incredible boost. In addition, presenters may connect the Acer K330 wirelessly to a laptop, tablet or smart phone through an optional USB Wi-Fi dongle.
The new Acer projector employs an environmentally friendly management solution — Acer EcoProjection — which reduces standby power consumption by up to 70 percent to only one watt per hour of usage. Additionally, it delivers 20 percent additional power savings if it does not receive a signal input after five minutes. An included tool also lets customers create customized power-saving configurations.
Price and Availability
The Acer K330 projector is available now for $419 in the U.S. with a 1-year warranty included.
See more about: Newest Projectors, Acer Projectors, DLP Projectors, LED Projectors
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
