Acer C120 LED Pico DLP Projector Announced
Acer introduced the C120 ultraportable pico projector that can be powered by a PC via USB connection. It is ideal for business people, instructors and anyone who needs an incredibly portable projector to display clear, crisp images.
The ultra-lightweight Acer C120 pico projector features an LED lamp, so it turns on instantly and is quickly ready to show vibrant images. Presentations can be enjoyed natively in the 16:9 aspect ratio at WVGA resolution (854×480) or at the maximum resolution WXGA (1280×800) in a 16:10 aspect ratio. Plus, USB 3.0 connectivity increases data transfer speeds up to 10 times faster than traditional USB 2.0 for enhanced image brightness and quality.
Customers have the additional flexibility of powering the Acer C120 projector directly from their notebook's USB port, so they can leave their power cord at home. This convenient USB 3.0 option allows for faster display of the images at a bright 75 ANSI lumens. Alternatively, when higher brightness matters most, customers can power the projector with the included AC adapter or any Acer notebook PC adapter to enjoy presentations in an even brighter 100 ANSI lumens rating. The new projector is also plug-and-play compatible with notebook PCs, so no drivers need to be installed.
Acer C120 LED Pico DLP Projector - Back
The Acer C120 has a high 1000:1 contrast ratio that results in crisp presentations and photos. The portable projector also ensures image quality and accuracy with improved color saturation (60 to 120 percent NTSC) and Acer ColorSafe technology. Color integrity is protected even after prolonged use of the projector.
The C120 projector fits in the palm of a hand and weighs only 6.34 ounces. It is incredibly compact, so it can fit in a purse or briefcase; it measures 4.72-inches (W) by 3.23-inches (D) by 1.0-inch (H). In addition, long battery life will ensure the Acer C120 will keep projecting bright images through the very last slide.
Maintenance is reduced for the product since there is no lamp to replace. Plus, the long 20,000-hour LED life ensures long-term dependable projector use. The Acer C120 has a wide projection throw range — it can project clearly from as close as 15.75 inches and as far as 12.14 feet away.
Price and Availability
The Acer C120 projector is available now for $259 (US). It is backed with a one year warranty. See more pico projectors.
Specifications:
Projection Method Front
Projection System DLP
Platform Supported PC
Display Panel 0.3″ DMD
Maximum Lens Aperture F/1.87
Lamp LED (LED life 20,000 Hours)
Standard Mode Brightness 100 lm
Color Supported 16.7 Million Colors (24-bit)
Native Resolution 854 x 480
Maximum Resolution 1280 x 800
Min / Max Projection Distance 15.75″ / 12.14ft
Input Interface USB (3.0, Micro-B) x 1
Warranty Projector – 1 Year Limited Warranty (Bulb: 90-day Limited Waranty)
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
