Aavik U-301 Unity Amplifier Combines Streaming, DAC, and 300W of Danish Power
Aavik U-301 Unity Amplifier combines streaming, DAC, preamp and 300-watts per channel in a $17,000 all-in-one component.
2026 Aavik U-301 Unity Amplifier Front Angle
Audio Group Denmark has introduced the Aavik U-301 Unity Amplifier, an all-in-one high-end component that combines a streamer, DAC, preamplifier, and power amplifier in a single chassis. Building on the original U-300 Integrated Amplifier from 2015, the U-301 is designed for listeners who want fewer boxes, fewer cables, and a far cleaner installation without accepting the sonic shortcuts that often come with conventional systems.
That is an increasingly relevant proposition at the upper end of the market. Plenty of high-end buyers still want exceptional sound, but not necessarily a rack full of separates, costly power cords, and enough interconnects to keep a small cable manufacturer in business. The U-301 is intended to preserve signal integrity, timing, low noise, and musical coherence by keeping the critical stages of the signal path under one roof.
Aavik is not a brand built around affordable entry-level products, and the U-301 makes the most sense within Audio Group Denmark’s tightly controlled ecosystem of amplification, streaming, cabling, power management, and loudspeaker partners. For the right buyer, however, that ecosystem approach may be the point: a genuinely high-end system with far less visual clutter and fewer opportunities for the weak link to announce itself.
A Complete High End System in One Chassis
The U-301’s preamp stage gives the one-box design a useful expansion path. Its single RCA preamp output delivers up to 7.5Vrms, with 76 volume steps in 1dB increments and quoted line-stage distortion below 0.005 percent, allowing the U-301 to drive an external power amplifier when more scale or a different amplifier pairing is desired.
aavik-u-301-rear
U-301 DAC: High Resolution PCM, MQA and Native DSD Support
Aavik’s proprietary DSD-upscaling DAC is not merely a digital convenience feature. The U-301 accepts PCM up to 24-bit/192kHz through BNC S/PDIF and optical inputs, while its USB UAC 2.0 connection supports PCM up to 32-bit/384kHz, MQA, DSD64, and DSD128. That gives the U-301 the format support expected of a serious high-end digital hub, while avoiding the usual pile of external boxes.
U-301 Streaming: A Wired Network First Approach
The U-301’s streaming platform follows Audio Group Denmark’s established ecosystem, using a wired Ethernet connection and the AGD Streaming App for iPad control. Built-in Wi-Fi and Bluetooth are not listed, and Android compatibility has not been indicated, so this is a deliberately focused rather than platform-agnostic approach.
aavik-app
Through the AGD app, users can access TIDAL, Qobuz, Spotify, vTuner internet radio, local music servers, NAS storage, USB hard drives, and USB sticks. Multi-room playback is also supported, allowing compatible AGD devices to be grouped together. It is a capable feature set, but one aimed at buyers comfortable with a wired network and Apple’s iPad ecosystem.
U-301 Amplification: 300 Watts Per Channel from Pascal Class D
The U-301 uses an amplifier stage derived from Aavik’s I-x88 series, built around Pascal Class D technology with high-speed UMAC modulation. Rated at 300 watts per channel into 8 ohms and 600 watts into 4 ohms, it is designed to provide the efficiency, low output impedance, and peak-current capability needed to maintain control over a wide range of loudspeakers.
Mechanical Grounding
darkz-feet
To address vibration-related noise, Aavik equips the U-301 with Ansuz Darkz feet, designed to limit the transfer of structure-borne vibration into the chassis. The company also offers optional Darkz resonance-control devices for owners who want to take that approach further.
These accessories use precision mechanical assemblies and hard materials to manage vibration and resonance around the component. It is a distinctly Audio Group Denmark solution: the U-301 is not treated as an isolated amplifier, but as part of a larger ecosystem where mechanical grounding is considered alongside power supply design and electrical noise reduction.
aavik-u-301-front
U-301 Design: Scandinavian Minimalism With a Purpose
The U-301 continues Aavik’s restrained Scandinavian design language, combining an aluminum frame, integrated cooling elements, large LCD display, substantial front-mounted control knob, and three integrated pushbuttons. Thick wood-based laminate top and bottom panels add warmth to what could otherwise be a very industrial-looking component.
The design, created by Flemming Erik Rasmussen, is intended to do more than look expensive on a rack. Aavik says the enclosure also supports resonance control and helps protect the audio circuitry from mechanically induced noise. As Michael Børresen, Audio Group Denmark co-founder and CTO, explains: “The design process of the U-301 felt like a return to Aavik’s origins and our first unity amplifier. With Flemming’s input, the U-301 pays homage to that heritage while clearly pointing toward the future.”
Aavik U-301 Specifications
Aavik Model U-301
Product Type Network Preamp/Amplifier and DAC
PriceEUR 15,000
USD 17,000
Line InputMaximum input 4.5V RMS
Input impedance 10kohm
Digital inputsCOAX – S/P-DIF: PCM 24-bit 44-192kHz and MQA
TOSLINK Optical – PCM 24-bit 44-192kHz and MQA
USB UAC 2 -PCM 32-bit 44-384kHz, MQA, DSD64, DSD128
Network Connectivity Ethernet
Preamp Output1 pair of RCA outputs
Speaker Connections2 x Binding Posts
Max output7.5Vrms
Distortion Line Stage<0.005% (THD at 1kHz, 1V input)
Volume Control76 x 1dB steps
Power Output2x 300W into 8Ω
Distortion<0.0028% (1W, 1kHz, 8Ω)
IMD (Intermodulation Distortion)<0.0008% (10W, 8Ω)
TIM (Transient Intermodulation Distortion)<0.002% (10W,  8Ω)
Control RS232, 12Volt Trigger Out
Dimensions (HxWxD)4.25 x 16.46 x 16.93 in
(10.8 x 41.8 x 43 cm)
Weight23.1 lbs (10.5 kg)
aavik-u-301-angle
The Bottom Line
The Aavik U-301 is not attempting to make $17,000 sound sensible to everyone. It is a serious one-box solution for buyers who want high-end streaming, digital conversion, preamplification, and 300 watts per channel without a rack full of components, cable clutter, and the usual matching exercise that accompanies separates.
Its real advancement over the original U-300 is not greater amplifier output, but a more streaming-focused architecture built around Aavik’s newer I-x88-derived Class D platform, resonant-mode power supply, and the broader Audio Group Denmark approach to electrical and mechanical noise control. The U-301 is a tightly integrated high-end system rather than a conventional integrated amplifier with a DAC bolted onto the side.
The glaring omission is the lack of a built-in phono stage. The U-300 offered one, while vinyl listeners considering the U-301 will need an external phono preamp, another cable, and another box. That rather undermines the “just add speakers” pitch for anyone with a turntable, although it does create an obvious path toward Aavik’s dedicated R-Series phono stages.
The U-301 will make the most sense for a streaming-first, two-channel listener who wants fewer boxes without stepping down into lifestyle-audio territory. It is not the connectivity equivalent of a Swiss Army knife, and the published materials do not position it as one. But for buyers committed to the Audio Group Denmark ecosystem and willing to pay for Danish engineering, design, and a very specific approach to system integration, the U-301 looks like one of the more ambitious all-in-one amplifiers available.
Price & Availability
The Aavik U-301 Unity Amplifier will be available for $17,000 (€15,000) beginning October 2026 through Authorized Audio Group Denmark Dealers.
For more information: audiogroupdenmark.com
2027 Onkyo HA-70 Headphone Amplifier Front
Onkyo returns to desktop headphone audio with the $650 HA-70, dual ESS DACs and balanced outputs. Is 80 years of HiFi experience enough to...
2026 Audiolab 3000A and 3000CD Silver Front 2026 Audiolab 3000A and 3000CD Silver Front
CD Players
Audiolab's new 3000A amplifier and 3000CD player cost $699 each, with the DAC living in the CD player. Is this a smarter way to...
2026 iBasso DC-Tonfa Dongle DAC Lifestyle 2026 iBasso DC-Tonfa Dongle DAC Lifestyle
Dongle DACs
The $359 iBasso DC-Tonfa combines an R2R DAC, 800mW headphone output and S/PDIF connectivity in one compact device.
2026 Vincent Audio SA-32MK and SV-737MK 2026 Vincent Audio SA-32MK and SV-737MK
Vincent Audio updates its SV-737MK and SA-32MK with HDMI ARC and Bluetooth while retaining hybrid tube circuitry. Is losing Wi-Fi a mistake?
2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle 2026 ELAC Debut Reference 3.0 DBR63 stand-mount loudspeaker lifestyle
ELAC's $899 Debut Reference 3.0 DBR63 gets an aluminum tweeter, new aramid woofer, and premium styling. Is this the bookshelf speaker to beat?
2026 Fluance RT86 Turntable Angle Black Lifestyle 2026 Fluance RT86 Turntable Angle Black Lifestyle
The Fluance RT86 offers a carbon fiber tonearm, acrylic platter, and cartridge choices in a single-plinth design. Is saving $100 over the RT87 worth...
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
Naim’s CI-Uniti 102 combines 150 watts per channel, streaming, HDMI eARC, and multiroom flexibility in a compact amplifier that raises awkward questions for the...
Why does Naim's new Uniti Star Lite lose CD playback during a CD resurgence? A discontinued drive forced Naim to rethink its 70W streaming...
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Cambridge Audio Evo 300 delivers 300Wpc, Hypex NCOREx power, StreamMagic Gen 4, HDMI eARC, MM phono, and big Evo ambition.
Are Aavik’s R-x88 Series the ultimate phono stages for MC and DS Audio optical cartridge users, or just Danish analog excess?
At $13,000, the Esoteric N-05XE combines streaming, DAC, preamp, and headphone amp duties into a Tokyo-built hub that impressed at AXPONA 2026.
Marantz's Model M1 packs 100W, HEOS, HDMI eARC, and Dirac Live into a compact streaming amp for only $1,000.
