New member Username: NeoinbizPost Number: 1 Registered: Nov-05 | I have room I constructed at 14x21 feet. 54" x 96" Da-Lite fixed mount screen Infocus 4805 Yamaha receiver RX-V2500 Polk R50 Front tower speakers (Will be in wall) 4 RC85i Polk for surrounds Velodyne DLS-4000 sub 2 questions. 1. Can anyone let me know what would be a good DVD player/recorder with DVI 2. Who makes good IR extender for remote control. I need something since I will have my A/V equipment out of line of site. 3. Is there a product out there that will let me view multiple video inputs at once? Like picture - picture ![]() ![]() |
Bronze Member Username: AcutemiPost Number: 17 Registered: Dec-04 | Wow Scott, this looks very familiar! I highly recommend the NuVo IR system, it works great and if you do some searching you can find it at a very reasonable price. For the PIP questions...how are you getting your tv signal? If you do it via HDTV computer (which I do) you are able to do PIP easily! I am using the Panasonic DVDS97S Progressive Scan DVD Player and it will upsacle to near HDTV quality and has HDVI output. There are many too choose from. You are in for nothing but FUN!!! Enjoy |
New member Username: NeoinbizPost Number: 3 Registered: Nov-05 | tv signal is from digital cable box |
Bronze Member Username: WestcottLeague City, Texas Post Number: 32 Registered: Oct-05 | I would try to get components with HDMI. That is really a better solution for future proofing your system. If you have to use DVI, run HDMI cables where you are likely not to have access to again and use DVI pigtails at either end. |
New member Username: Abbaskhan8008Chiniot Pakistan Post Number: 2 Registered: Mar-25 | Deal Wiki only shares verified discounts, but some deals expire. Always check the expiry date before using a coupon. 3. Can I Use Deal Wiki on My Phone? Yes! Amazon deals works on both computers and mobile phones, making it easy to find deals anywhere. 4. What Kind of Products Have Deals? You can find discounts on electronics by visiting this best content, clothing, home items, groceries, beauty products, travel, and more!} |
