New member Username: SleatsPost Number: 1 Registered: Aug-13 | This forum is far more advanced than my knowledge base. I've read through a couple threads and see that my looking at "numbers" to assess value may not be the right approach, but I lack time and don't want to dump serious money into speakers. I am debating whether to buy, unheard, Polk Atrium5's vs Polk Atrium6's. The specs are essentially the same but the 6's add roughly an inch in size in all three dimensions and can get down to 50Hz vs 60Hz for the 5s. I don't really want to spend more than these speakers are available for. I've focused on specs here which might irritate Jan, but NOT my intention. Question for the experts: What is the best value in an outdoor speaker today? The living space in my yard is relatively large and I want the speakers to sound "good" high/low volume, nearby or swimming in the pool ... Any and all thoughts appreciated. I cannot listen before I buy ... Thanks! |
New member Username: Turnerdaniel770Post Number: 4 Registered: Jan-14 | I saw some outdoor speaker on some online stores like ergode.com and virventures .com. You will get it in reasonable price too. |
Gold Member Username: MagfanUSA Post Number: 3100 Registered: Oct-07 | No matter what you end up with, location of the speaker is very important. If you can 'back' the speaker up against the house, you'll improve all aspects of the sound. You should get more bass and ultimately it'll play louder, too. This is as opposed to putting the speaker in the middle of a big flat area. Keep in mind you will probably do LITTLE 'critical listening' and probably just want background music. I get much the same effect just cranking my system up�.when I adjourn outside for a sit and an adult beverage. I sort of doubt it will matter WHAT you buy, as long as you experiment with location of the speaker before you nail 'em down. I personally like�..if I had a use for 'em�..EVE MOUNT speakers which'll be out of much of the weather and SUN.. What are you using for an amp? Do you have a speaker switch box or is it internal to the amp? Make sure that for longer speaker runs, you at least consider 1 size larger wire�.(for runs over say��30 feet) |
Silver Member Username: EdisonGlendale, CA US Post Number: 961 Registered: Dec-03 | Nile speakers are nice - they will play at a higher level than the Polks, but speakers are rather personal, and have to be heard in person before buying, if at all possible. If not, then at least try to hear them on youtube.com if you can find a them there... |
New member Username: Josh_butler0123Post Number: 1 Registered: Dec-21 | I love the convenience of portable bluetooth speakers. But for those who want a more permanent and high-quality outdoor audio solution for the backyard or patio, let me suggest a good pair of weatherproof outdoor speakers. The OSD Audio AP650 speakers are your best choice because they sound great, mount easily, and are built to endure harsh weather and resist invasion by bugs and dust. |
New member Username: SheqyPost Number: 1 Registered: Dec-22 | I remembered there was TANNOY DC 8 or dc12 outdoor speaker, thay might be still available second hand somewhere. They had this great dual concentric design. Sorry I am bit late for the party but somebody might find it useful. |
New member Username: BrookPost Number: 2 Registered: Jul-24 | t seems that you are searching for a balance between quality and performance that doesn't cost a fortune, which is especially true as you can't try out the speakers in person before making the purchase. The main differences between Polk Atrium5 and Atrium6 are the size and the lower frequency response of the Atrium6 (which can reach 50Hz, in comparison to the Atrium5's 60Hz). Nevertheless, the decision comes down to the size of the space and the value you put on low bass. If your outdoor space is big and you are after fuller sound, the Atrium6 may provide slightly better performance at lower volumes and in deeper bass. Nevertheless, Atrium5 is still a good-sounding budget alternative if you're looking for something cheaper. The question of which outdoor speakers provide the best value comes down to the fact of how these speakers are going to behave in different environments the main being the outdoor acoustics. Other brands such as Klipsch, Yamaha, and AQUATIC AV - PRO Sport 6.5″ Waterproof RGB Speakers also have good alternatives in the same price category. Eventually, both the Atrium5 and Atrium6 remain good choices; thus, the factor you should consider is the additional money spent on a larger speaker size and lower the bass extension (if your budget allows).https://www.mazuzee.com/index.php?route=product/product&product_id=3384 |
