Bronze Member Username: LevelzeroPost Number: 43 Registered: Aug-07 | I was playing around with my new camera. ![]() |
Silver Member Username: DeadhorsePost Number: 119 Registered: May-06 | Are those your rear speakers on the stands? Obvious next question...why are they in the front? |
Bronze Member Username: LevelzeroPost Number: 46 Registered: Aug-07 | I was sitting on the couch, in the dark, when I took that picture. The light, of couse, is from the flash. The rear speakers look like the ones you see on the stand, but they're behind the sofa. It's a 7.1 Onkyo system. You can't see the other components very well, but the receiver and disc changer is on the right side of the stand. |
Gold Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1687 Registered: May-07 | i got the 7.1 onkyo too.. Sh1t is badazz, but i upgraded the Sub wit an 18inch |
Silver Member Username: Shane24TorontoCanada Post Number: 226 Registered: Mar-07 | bullshit system.. |
Bronze Member Username: Abbaskhan8008Chiniot Pakistan Post Number: 21 Registered: Mar-25 | This setup looks powerful�great attention to acoustic detail! When building or upgrading rooms for home theaters or audio setups, precise groundwork matters a lot. I recently found an excellent solution for generator rental in abu dhabi that ensures clean, level surfaces for cable trenches and subfloor installations. A solid foundation really enhances performance! |
