97 Jeep Wrangler
Username: Mesodumm
Dewey, Az Usa
Post Number: 18
This is my 97 Jeep Wrangler, its got 2 12" M3MOJO12 in 3.44 cu ft ported box tuned at 38hz with a mcd1500 1500 watt at 2 ohm running them.
3 pair 6.5 coaxial 15-msc, 1 pair 4x6 coaxial 15-mc4.6, ran by a mca5004, with a VR3 VRCD400-USB cheap deck but works great never a single problem with it!!
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2254
looks nice man
Username: Trey4sports
Post Number: 1054
clean install bro, looks good all the way around, but are you sure you wouldnt rather have an 18" 06 RE XXX ??
Username: Mesodumm
Dewey, Az Usa
Post Number: 21
Hey Thanks!! Reese and Trey,, do you have pictures I like looking at other systems gives me ideas on what to do next!! I have been working on my wifes Jeep lately, she is mail carrier with 2006 Wrangler, she can't loose any room so I did 1 12" behind seat, 1/3 of air space is under seat and fiberglassed into side wall. I'll post a pic so you can see. While I do that put some of your up!!!!! Thanks again! Chad
Need to Register?
Forgot Password?
Enable HTML code in message
