Alpine type r
Username: Kory_m
i have two 12 inche alipne type r subs and a 600w alpine v12 amp is that enough to power both of the subs
Username: Blainew
Post Number: 2370
no
Username: Kpa2727
Post Number: 310
nope only 300 watss to each woofer that would give, i'm giving mine 600 rms to one and it's not enough.
Username: Sqcheap
Grand rapids, Michigan Usa
Post Number: 26
It will work, also depends on what enclosure you are using them in. No it might not max them out.
Username: Sqcheap
Post Number: 27
Also depends on if that is 600w rms or not. The big old alpines put out pretty good, like the 1000.
Username: Kpa2727
Post Number: 313
ok but were talking on a safe level. yes 300 rms can make them move but not jump and kick like they should. and u come into the clipping/overdriving amp issues at really low rms.
Username: Sqcheap
Post Number: 31
I agree. If you used a large ported or IB mounting then they would need less power for example. If you want max spl you will need a tighter enclosure and more power. If you are just listening to music 600rms should go pretty loud, 300rms will work but like Keith says the subs can give you more with the right power. My friend has I think a mrv1000 V12 alpine and it is not overrated, I have seen them go for 200+ on ebay. Its the darker silver color with the thick fins. It is rated at 600rms.
Username: Wojopro
Summerville, SC
Post Number: 258
Woah! Depends on which type r's you have. The new ones are rated for 500 watts rms. The older ones are rated for 300 watts rms. Or something like that... Trying to find the exact specs
Username: Kory_m
well i have had the subs for a good 4 months now and they sound so fricken sweet and i have won a couple battles wit them so they should be pretty good
Username: Dubmc23
Rapid City, SD USA
Post Number: 129
same here i have probably a little over 600 rms goin to each one and they sound amazing...
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13450
a couple battles???
I dont get it?
Username: Sqcheap
Post Number: 101
V12s are pretty good amps IMO, though I'm switching to newer class D to reduce power draw.
Username: Kory_m
like when you go to a sub contest you beat other kids with subs and that is what a battle is
Post Number: 13454
how do u tell who wins??? is it by ear?? Is there a meter?? Port wars?? I just wanna no the rules
Username: Kory_m
there is a meter that measures something, and they give you a cd that you have to play and then who ever measures the highest on the meter wins
Username: Kory_m
Post Number: 7
Username: Naledge503
Http://www.LowDownForu...Zac Davis 4 ...
Post Number: 2554
what was your score?
Username: Somedonniedude
Illinois United States
Post Number: 676
Can I play this game?
Post Number: 677
Sorry I meant battle.
Username: Vc23
Fi , 2 12 Fi Bls U.s.a
Post Number: 242
haha... i want to play as well... but can i just scream as loud as i can....i know thats like 125 db at least and that should do it......
Post Number: 680
Just dont hurt yourselves, its hard to burp a 45hz tone from your vocal chords with out burning your throat
Post Number: 13469
yea...^^^I burnt my 0.98425inch vc's (vocal chords) the other day
Username: Sqcheap
Post Number: 105
You need some soda or other carbonated beverage...potato chips, and you don't use your vocal cords...still might be hard to hit 45.
Need to Register?
Forgot Password?
Enable HTML code in message
