Should i get this box for some L7's
Username: Ceoofdaroc4
http://cgi.ebay.com/SOLOBARIC-SQ-HOLE-10-KICKER-CAR-AUDIO-SUBWOOFER-BOX_W0QQitem Z270093449991QQihZ017QQcategoryZ14945QQrdZ1QQcmdZViewItem
would this be a good box to get for 2 kicker L7's or does it look cheap to you guys or should i go with a ported box?
Username: Jkidder
Spring hill, Florida Usa
Post Number: 330
go ported. how much r utrying to spend on a box?
Username: Sheriff
Post Number: 50
Definitely go ported. Try to make your own. People will help you out on Ecoustics.
Post Number: 12
I don't have the tools to make my own.
Username: Nd4spd18
Southeast PA
Post Number: 676
Wrong section.
And don't buy a prefab box, they suck. Have a custom box built.
Need to Register?
Forgot Password?
Enable HTML code in message
