Bronze Member Username: 1lakerfanPost Number: 52 Registered: Apr-06 | Reciever: Denon 2807 Fronts: Polk Audio RTi10 Subwoofer: Velodyne DLS-4000R Surrounds: Onkyo (looking to upgrade) Center: Onkyo (looking to upgrade) ![]() ![]() ![]() ![]() |
Bronze Member Username: MsvaraPost Number: 27 Registered: Sep-06 | Nice audio. Now save up and get a new 1080p TV ;) |
Gold Member Username: DelsolePost Number: 1098 Registered: Feb-05 | lookin good how does it sound |
Bronze Member Username: 1lakerfanPost Number: 58 Registered: Apr-06 | It sounds good, i'm looking to replace the center speaker. I'm looking at the polk audio csi5 right now. any suggestions? The csi5 is voieced matched for the RTi10s |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 33 Registered: Nov-06 | i have the rti10s and am using the csi3 center and it sounds real good. im not an expert but ive done a lot of reding and comparing, and i think the csi5 is more for the rti12s because of the power hanling and the size of the speakers. how is the velodyne? i was going to buy that one but polk had a special, if you bought 500.00 worth of speakers you got a 199.99 sub or could use the moneyto ofset the cost of a better polk sub , so i got the psw12 and it works fine, |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 34 Registered: Nov-06 | sorry my typing is bad... how do you have your speakers connected ? i have mine bi-wired. some say it makes no difference but im using 12 ga. speaker wire from loews. so it was worth any possible improvment. |
Bronze Member Username: 1lakerfanPost Number: 59 Registered: Apr-06 | The velodyne DLS-4000R sounds excellent. I am not bi wiring. I still need to buy better speaker wire. I am using the speaker wire that came with a onkyo home theatre in a box which is thin speaker wire |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 35 Registered: Nov-06 | i bought about 50 ft. of 12 ga. wire from loews for about 12.00 and bannana plugs from rsdio shack for about 4.00. a set, then covered the whole thing with wire loom tubing not bad for the cost. |
Bronze Member Username: 1lakerfanPost Number: 60 Registered: Apr-06 | Do you hear a difference in sound from a cheap speaker wire to a expensive one? |
Silver Member Username: GamerdudeOntario Canada Post Number: 300 Registered: Apr-06 | Nice |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 36 Registered: Nov-06 | ive never tried one but ive read that there is no difference. but ithink they look a lot nicer, monster cable makes one that has the bannana plugs on the ends. i want to buy a set and try them out but they cost around 100.00 a set for 10 feet. crutchfield has them in three different lengths. |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 37 Registered: Nov-06 | what kind of veneer do you have on your rti10s? i have the cherry and its verry smooth to the touch. do you play them with the covers on or off? |
Bronze Member Username: 1lakerfanPost Number: 61 Registered: Apr-06 | I have the black color and keep the grill on because afraid I might mess them up with everything exposed |
Gold Member Username: Thx_3417Post Number: 2313 Registered: May-05 | Albert Yes I must say I like the Denon 2807. Was just looking it up in Google image and I liked what I saw very nice indeed. |
Bronze Member Username: 1lakerfanPost Number: 62 Registered: Apr-06 | I just upgraded my center speaker to the polk Audio Csi 5 and should arrive in a couple of days |
Silver Member Username: GamerdudeOntario Canada Post Number: 315 Registered: Apr-06 | The thicker the wire the more power will go threw. Thinner stuff is fine for twets/mids but for woofers thicker is better Just get some 16ga |
Bronze Member Username: 1lakerfanPost Number: 64 Registered: Apr-06 | Monster Cable ULTS1000MT-10/10 Ultra Series THX 10 Foot Pair Spkr Cable What size is this speaker wire |
Bronze Member Username: ShamuchefCentral florida THE GREATEST... Post Number: 39 Registered: Nov-06 | that speaker wire is a rip off. i ordered it from crutchfield and it sounds no different than regular 12 ga. speaker wire. its just a mental thing. like my rims are better than yours , the car rides no different than with the stock rims. its the best way to explain it. but some people are not happy unless they waste thier time and money |
Silver Member Username: Arande2400dB could probably d..., 4000 isnt ev... 100,000dB FU... Post Number: 202 Registered: Dec-06 | My dad works as an electrician at this manufacturing facility and he brought home to me a piece of copper wire with a 2" diameter! Lol that'd be overkill. |
Bronze Member Username: 1lakerfanPost Number: 65 Registered: Apr-06 | Whaht speaker wire would you recommened |
Bronze Member Username: 1lakerfanPost Number: 66 Registered: Apr-06 | Upgraded center speaker to polk audio csi5 ![]() ![]() |
Silver Member Username: Arande2400dB could probably d..., 4000 isnt ev... 100,000dB FU... Post Number: 481 Registered: Dec-06 | Good. |
Silver Member Username: GamerdudeOntario Canada Post Number: 324 Registered: Apr-06 | Just buy some Monster THX speaker wire its 16 GA it works fine i use it for all my speakers http://monstercable.com/THX/productPage.asp?pin=1602 |
Bronze Member Username: Mattman12Post Number: 12 Registered: Jan-07 | Nice speakers but I would have went with a bigger stand to support that TV. |
Bronze Member Username: 1lakerfanPost Number: 75 Registered: Apr-06 | Added a PS3 |
Silver Member Username: WestcottLeague City, Texas Post Number: 165 Registered: Oct-05 | Looks like you are off to a great start and your speaker placement is good too. I too would be inclined to upgrade the display first to go along with the great audio. Congratulations and hope you enjoy your system for some time to come! |
Bronze Member Username: 1lakerfanPost Number: 82 Registered: Apr-06 | I was looking at the Sony 40" BRAVIA V-Series HDTV (KDL-40V2500) and the Sony 40" BRAVIA XBR LCD HDTV (KDL-40XBR2). I was plany on getting the XBR2 but I heard that there are alot of compaints about this tv being clouding and the customer service dosnt help a all either, so I'm not sure which one to get. I really wanted to HD tv for my ps3, for playing games and playing blue ray movies. here is link that compare the two tvs. http://www.circuitcity.com/ccd/compare.do?poids=160778,157555&prevPage=categoryl ist.do&catOid=-12869&nstr=20012866%2020012867%2020012869%20965%2040000129&link=r ef |
Gold Member Username: John_sColumbus, Ohio US Post Number: 1420 Registered: Feb-04 | I just don't see enough of a difference between these TVs to warrent paying $650 more for the XBR. You do get an extra HDMI input and better remote with it, but that's about it as far as I can see. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1919 Registered: Dec-06 | More powerful subwoofer system needed...come on man! |
Bronze Member Username: 1lakerfanPost Number: 83 Registered: Apr-06 | You mean I need a more powerful subwoofer?! Velodyne makes the best subwoofers. Have you heard this subwoofer? Look at this link http://www.velodyne.com/velodyne/news/review_files/home%20theater%20dls-4000r%20 july%202004.pdf |
Gold Member Username: Joe_cAtlanta, GA USA Post Number: 1406 Registered: Mar-05 | ![]() |
Silver Member Username: WestcottLeague City, Texas Post Number: 174 Registered: Oct-05 | There is an old saying, "Quality over Quantity" and the Velodyne is just that. One of the best sounding subwoofers in the market. Good bass is an acquired taste. Until you have heard it, you really do not know what you are missing. Too much of it and all you do is destroy the rest of the frequency range. The Velodyne plays flat over its entire capable range and that is no small feat. Some people go through life talking every minute of it but in the end, they really do not have much to say. |
Silver Member Username: DavidpaPortland, Oregon US Post Number: 414 Registered: Nov-05 | C'mon, we all know Andre hasnt heard a quality sub yet. But if its loud, hes OK, still young, he'll learn. For your TV, look into Panasonic TH_(insert model # here)U series, GREAT bang for the buck. As of now, I believe that series (all sizes) is outdoing all other comers, kinda like the Sony "ruby" has been doing to other high Gs projectors, including their own Qualia. I picked up the TH58PX600U after demoing quite a few, and glad I came across it, because otherwise I would've spent about a 1/3 more for no reason other than to say I spent more. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1927 Registered: Dec-06 | My favorite sub I've heard so far is the ML Descent, like I said on my very first post here. It sounded natural and it was great especially for music. I plan on building an IB consisting of 4 18" Q's and an EP2500 to supply power. You're right david, I haven't heard a quality sub until I've heard a well built IB! ![]() You know they always say that when we say we're looking for more bass, but what we're really looking for is better bass! Oh, btw that's what I was suggesting, an IB! Lots of power down to 10hz |
Bronze Member Username: 1lakerfanPost Number: 84 Registered: Apr-06 | Post you setup or give me a link to your set-up |
Gold Member Username: Joe_cAtlanta, GA USA Post Number: 1410 Registered: Mar-05 | Here is Andre's setup Merry Christmas!!!!! ![]() |
Bronze Member Username: 1lakerfanPost Number: 85 Registered: Apr-06 | am I supposed to be impressed? |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1952 Registered: Dec-06 | Lol maybe ASHLEY's setup...but right now I'm waiting to get what I need to build the IB. If only I had a camera. |
Bronze Member Username: 1lakerfanPost Number: 86 Registered: Apr-06 | what is your budget on you whole entire surround system? |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1963 Registered: Dec-06 | Well let me see, I'm 14... and so I've only spent a total of maybe $500 in it, but if it were all new, maybe $4000? I do like your system, although it probably wouldn't have been my first choice of components. ![]() Anyway, I'd rather have your setup than some cheap setup that was all the cheapest stuff you could find at bestbuy or something. I KNOW that your setup beats a lot of 'em. I'm just building mine step-by-step and hopefully that speeds up when I can get a job working somewhere. ![]() |
Bronze Member Username: 1lakerfanPost Number: 87 Registered: Apr-06 | what do you mean when you say "so I've only spent a total of maybe $500 in it, but if it were all new, maybe $4000?" |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1980 Registered: Dec-06 | I mean I've bought it all used. |
Silver Member Username: GamerdudeOntario Canada Post Number: 456 Registered: Apr-06 | Andre , Its not about beating other peoples system. If you like it, you like it. same with Ashleys system it prolly sounds wicked when watching a movie, it may not look all that good but it potlly sounds wicked. Its about how it sounds to you. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1987 Registered: Dec-06 | That's what I was going to say up in that other post, but I guess I got distracted; totally agree with you. ![]() |
Bronze Member Username: Movie_collector, California U.s Post Number: 14 Registered: Jan-07 | Al $400,$4000 or $40k. Bottom line is, what sounds good to you. These other guys that knock your system are low life punks that need Mommy and Daddy to pay for their equipment. You cant truly enjoy shaking pictures off the wall until you pay for it all your self. Took me 12yrs of trial and error before I finally got the right combination that met my needs. Take a peak at my profile when you get a minute. |
Silver Member Username: WestcottLeague City, Texas Post Number: 196 Registered: Oct-05 | Albert, Monster Cables are overpriced and are not well shielded. I suggest you visit Blue Jean Cables site. Fair prices for broadcast quality cables without all the sales gimmicks. |
Bronze Member Username: 1lakerfanPost Number: 88 Registered: Apr-06 | Andre Money, If you like that sub, than thats you opinion. I just want to say that theres more to a surround system than just the sub. I seen some of your replies on other peoples systems and you keep saying "need more power" or something like that. having a good subwoofer isnt going to give you the complete surruond sound |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 2056 Registered: Dec-06 | Did you notice I made most of those comments within a 5-minute period? I must've gotten angry (don't have a sub yet). I guess it can if it's the only thing missing. Of course, if everything else is good enough, you don't even need a subwoofer! I do though. It's only as good as its weakest link. |
Bronze Member Username: 1lakerfanPost Number: 93 Registered: Apr-06 | I heard the Sony XBR2 is having a problem on the tv being clouding. But someone said that it is only having this problem on the 42" tvs and up. Is this true because Im thinking about buying the 40" one. |
Gold Member Username: IlluminatorUSA Post Number: 4910 Registered: Apr-05 | Regarding the original post: there seriously needs to be a TV replacement next :P |
Bronze Member Username: 1lakerfanPost Number: 94 Registered: Apr-06 | If you read my last post you can see thats what im working on |
Silver Member Username: WestcottLeague City, Texas Post Number: 206 Registered: Oct-05 | Albert, The XBR has a great picture, but i seem to be seeing above average failure rates when compared to my other personal favorites, the Pioneer and Panasonic models. Your mileage may vary but I would do a search and see if you agree. |
Gold Member Username: IlluminatorUSA Post Number: 4928 Registered: Apr-05 | Ah yes, Sony. They do have a very nice picture, but the failure rate on them is disturbingly high... |
Bronze Member Username: 1lakerfanPost Number: 97 Registered: Apr-06 | Actually now I pretty sure I going to buy the Sony XBR3. I have found no bad reviews for this tv and I found this tv on the internet for about $2600 with a 3 yr. warranty (in home), but it will probably take me about three months until I actually buy this tv. This tv should go perfect with my Playstation 3. |
Silver Member Username: WestcottLeague City, Texas Post Number: 208 Registered: Oct-05 | Sony TV warranties are worthless. The XBR line has had issues. I suggest more digging. the XBR3 may not have anything yet, but it is still fairly new and is "cut from the same cloth". I have a Sony display so I not a Sony hater, just certain product lines for reasons mentioned above. |
