Here are some pics of my Tahoe- Still a few things to be done, but I'm happy so far. The sub and amp were designed to sit hidden under the rear seat and it also has a JL Audio 8" sub tucked away in a Q Form enclosure in side the center console. The box and amp mount were fleckstoned.
Yeah, I made it myself. It is about .75 cubic feet sealed and holds a JL Audio 10. I sacrificed a little output to fit it under there, but along with the sub in front it sounds great. If you want the dimensions, I'll measure it and get it to you. I lost the original plans I drew up. That is a Sony amp I got for $99 store display- I try to keep things inexpensive. It is impressive overall for the price, but I would lve to put some more power to the subs in the future.
if i had somthing as big as a tahoe i would fu*king go crazy with subs and amps and electrical upgrades and it would probably keep me broke for months trying to do all i would want to do .. but i guess ur stuff isnt bad if you arent a big bass head
I agree. If my cars had not been broken into so many times I would love to go with at least a couple of 12's. That's why the whole idea behind this is stealth, but I sure wouldn't mind a bit more boom.
