Finally Some day Pics, My pics at night are in another thread. I Have a RE SX15, Re 12.1, Tsunami 1.2 Farad Power Cap, Alpine MRV-F340, Clarion VRX755VD head unit, 6.5" Alpine Type S Coaxils in back and 6.5" Infinity's in the front ( I forget what model) Let me Know what You Guys Think...
Can I ask you how you have your sub wired? I have an 12" sx and a 12.1 as well but i have had many problems with the amp. Is your sub the standard dual 2 ohm or did you special order it?
the SX is dual 2 ohm, wired to 1 ohm. As you know the amp puts out 1200 RMS x 1 at 1 ohm (more when engine is running). I have not had any problems with the amp, I love it, tons of power. I have the gain at about 1/2.
I can see that your amp is bridged right? I have wired a 10" L7 and the amp can't move it at all. I sent it back to RE and they sent it back with a testing sheet and it says that it puts out 1270 wrms at 1 ohm. I am also thinking it could be my head unit which is 2v pre amp. I am thinking of getting the new Premier 880 or the 980 im not sure yet. Maybe that will help out a little or I am also thinking it could be the alternator. Thanks for the quick response and I really like your setup. very clean.
hey mike jones , was that box hard to make for your camaro i have a 85 camaro that i half to make a custom box for, do you knwo how many cuft your box is?
to answer all of your questions, I had a car audio place build the box, its 4 cubic feet. The ground wire is 0 gauge and the power wire is 4 gauge, I had 4 gauge with my old set-up and just never got around to changing the wire to 0 gauge cuz i'm lazy. I did change the ground because I could do it pretty quickly. The amp still gives plenty of power. The port is like 7 or 8 inches in diameter (in the actual pipe, not the black piece at the top) I have had the infinity's for a while and just recently I got the type S's from a friend that sold them to me brand new for $20....can't beat that, they sound good together, I can't notice a difference in them being 2 different pairs of speakers. My port rattles a shitload though and I don't know what to do to stop it. the port goes down and elbows towards the subwoofer inside the box, and then its just the open PVC pipe sitting inside the box, like 3 inches from the bottom of the box.... if somehow I could stabilize it maybe it wouldn't rattle as much.... any suggestions???
hey mike i think camaros an firebirds an trans am got like the same hole thing in the haych or w/e lol but is der any way u can get a pic of the whole box outa the car cause i got 2 10 sx in a firebird an the biggest box i got 2 fit is a 2.6cuft in the hole an i wanna go bigger 2 make the sounds sound louder but i can only get the 2.6 cuft i just want sum pics so i can c how they build it 2 git the 4 cuft that would b great thankx
hey mike jones can u make ur hatch do like a wave thingy from side 2 side with the low bass try mike jones.. what ya know or yung joc.. patrone i just noticed the front windsheild an the roof flexin not as much but u can c it move in an out go0d. roof anit goin 2 flex alot since its small an an braced up unlike them 4 door cars an suvs hatch flexes pretty go0d
S.P.D. what kind of amp is that and whats it put out? I will get some pics of my box for you and put them up asap. How do the 2 SX10's sound? In your opinion do you think its better than my SX15? What color is your neon bars? If you look in my pics I have Streetglow (blue) LED's that highlight my system. I superglued them on to the panel near the speakers in back.
iam just usin it as a strobe but i got a black light 2 light up the white furr but got blue under car kit under the car an its a orion 2500d 1700W @ 2ohms since the subs are dual 2ohms had the subs for awhile but didnt have a amp an if i new i was goin 2 get this amp i would have goten dual 4ohm subs an its pretty loud but i no i can make it way louder if i had room for a bigger box but the amp puts out 2500W @ 1ohm
i love them camreos an trans ams an firebirds just the shape lol i wanan get tint on it but my mom said no but i got the 5% on my car but the bird got sum 17s an decals an system neons an sh1t liek that when i get a chance 2 go 2 homedepot iam thinkin of buyin 4 sheets of mdf an can u open the paint program an draw the box an right how big the pieaces are that would b great its goni 2 b a custom custom box lol an u might wanna seal up the hole where the wire is an should i do a slot port might b kinda hard or shoud i use pvc?
i tryed buyin the 12/1 but they wasnt sellin them 2 ppl anymore only dealers an i should b atlease runnin 2000W but they r dual 2 so i could only get them @ 2ohms dotn wanna fry the amp @ .5 ohms
mike jones u gota sn so when can talk about that box cause iam buyin 3 sheets of wood 2mar 2 sheets for my 8cuft box an 1 sheet for the firebird box like urs mine sn is SHADYLIMITEDX
