WIRE?
Username: Jl_rock
Temecula, California U.S.
Post Number: 86
what size wire should i get for a 150watt(RMS) 300peak?subwoofer
Username: Illuminator
Post Number: 2863
It really doesn't matter, though 16 gauge works nicely for almost any (normal) speaker application.
Username: Ascleanasitgets
KingstonCanada
Post Number: 22
go all out get 10 or 12 AWG make sure your not loosing anything??
KingstonCanada
Post Number: 23
what kind of sub are you using and why are you using speaker wire anyways???
Post Number: 2885
Good point about speaker wire for a sub when it should just be RCA wire...
Don't you think 10 or 12 is a bit much?
Username: Jl_rock
Post Number: 87
I bought 18 feet of 12 gauge wire.
Username: Project6
Post Number: 7512
Is this a powered sub?
Username: Jl_rock
Post Number: 88
no its a car audio component, insignia!
My 400 watt stereo is the power!
Username: Shawndecker1
Pine hill, Nj Usa
Post Number: 13
I just wired my custom built 500w rms home theater sub with 12 ga and it still seemed like overkill. Joe's right though, why chance losing anything in transfer? You paid for the watts, might as well hear them. You really can't oversize, only undersize, so go pro and pay for the extra copper.
KingstonCanada
Post Number: 29
its the only way to go but if its powered you shouldn't need speaker wire on it anyways but if your tryin to tell me your using an insgnia car sub you should probably just light your system on fire and call your insurance company cuz inginia is brutal i work at future shop and i'm willing to admit it
Username: Project6
Post Number: 7829
Speakers don't have watts.
Username: Willieman
PR USA
Post Number: 40
Username: Hannjeff
Halifax, Nova Scotia Canada
Post Number: 91
thsi is a home teahtor area, not car audio
Need to Register?
Forgot Password?
Enable HTML code in message
