Dedicated Home Theater (under construction) pics
Username: Demfourlife
Post Number: 11
This is my work in progress. I will update as I go along until the project is completed.
http://community.webshots.com/album/526640264LuzePq
Post Number: 12
By the way, here is what will be going inside:
50" InFocus DLP RP (which will hang on the wall)
InFocus 4805 FP (which will hang about 13' from InFocus screen)
Pioneer 1015 Receiver
HR10-250 DirecTv Receiver
Samsung DVD-HD950
Gefen 4x2 HDMI Switcher
JBL S-38II (Fronts)
Athena AS-IC8 8 Inch 2-Way In-Ceiling Speakers (Sides)
Athena AS-IC8 8 Inch 2-Way In-Ceiling Speakers (Rears)
Dayton 12" Powered Subwoofer
6 Bass Shakers Pro (50 watts per shaker)
Username: Nemen
Trinidad & Tobago West...
post back on how you like them bass shakers.
Username: Daniel_canada
Post Number: 177
Any updates?
Username: Apresler07
Canal Winchester, Ohio USA
Post Number: 41
How are those bass shakers working out for you. I was thinking about getting some but i wasnt sure how good they would work.
Need to Register?
Forgot Password?
Enable HTML code in message
