Bronze Member Username: Joe_cOakwood, Ga Post Number: 92 Registered: Mar-05 | Ok I've just completed my dream, here it is: denon 6.1 amp, jbl e's all way round (7.1 setup w/ rears bridged)mits 55" wide, sony 400 dvd chgr, monster power station/line filter, all monster 3 series audio and video and speaker cables, phillips pronto remote (with lighting control), xbox (linked with another upstairs)dish 811, chater cable also for locals in hi def, and finally my jewel a sumiko project turntable(still luv the vinyl). The room has black dyed burlap on all walls, ceiling is painted flat black as is the crown and trim mold, 12" of wall and insulation, and finally the couch you see is decieving it is 10ft by 7ft with a 4 x 3 ottoman, the other room before the theater is an office with fish tank(37 gal fresh) exercise machine(dust collector) futon and desk with storage cabinets. Whadda ya think??? ![]() ![]() ![]() |
Bronze Member Username: Javmo200Michigan Post Number: 28 Registered: Mar-05 | Very nice Do you have a picture of your rear 4 channels? What kind of remote do you have? I lIKE IT |
Bronze Member Username: Joe_cOakwood, Ga Post Number: 95 Registered: Mar-05 | its really hard to get a good shot in that room without flash and it doesnt do it justice, I have the pronto ng 3000 |
Bronze Member Username: Joe_cOakwood, Ga Post Number: 96 Registered: Mar-05 | here are some other pics ![]() ![]() ![]() |
Bronze Member Username: Bnd_rulezPhoenix, AZ USA Post Number: 90 Registered: Mar-05 | Holy cow, how much did that set up cost? |
Bronze Member Username: Javmo200Michigan Post Number: 29 Registered: Mar-05 | Joseph Can you tell the difference between a 5:1 and 7:1 channel? I really like your set up. I am wire to 7:1 how ever I am only going to install a 5:1. my problem is the distance between back and side surround speakers is to close and looks crowded. The installer told me to hold on and just do 5.1 now--so now I have a brand new inwall klipsch speakers ( For sale) ...JM |
Bronze Member Username: Joe_cOakwood, Ga Post Number: 97 Registered: Mar-05 | if you can get the side (5.1 surrounds) to the side of you as much as poss. then go with 7.1 . mine are 2ft in front of the listening position and the backs are obviously behind me, but the distances for the sides and backs are the same which is important even if you amp designates distance. Both are at 70" high but the whole key to this sounding great is the room. I had this same setup in the upstairs living room and it doesn't even hold a candle to this setup. The rectangle room, the fabric on the walls and the perfect distances made all the difference. Javier the thing about 7.1 or even 6.1 for that matter is the 360 deg sound field you just dont get with 5.1 so my advice is try to sqeeze one in back there. David if I had to guess I would say that I have $9000 in equipment and $5000 in dvd's and $4000 in the room inc. the couch. |
Bronze Member Username: Javmo200Michigan Post Number: 30 Registered: Mar-05 | JC Thanks for the info--I will go for it--I am trying to post pictures of our place (under const) but I can say image to large..oh well I will try later-- |
Bronze Member Username: Joe_cOakwood, Ga Post Number: 98 Registered: Mar-05 | open image with "paint" and use the stretch/skew tool to reduce it's size |
Silver Member Username: Joe_cOakwood, Ga Post Number: 105 Registered: Mar-05 | had just a couple more to show (sorry but I worked so hard on this) ![]() ![]() |
da/ve yea baby! Unregistered guest | Very impressive system (and office area). I like the setup, lighting, and attention to dimensions. I like the cabinets and fishtank (cool!). Great job |
Silver Member Username: Joe_cOakwood, Ga Post Number: 144 Registered: Mar-05 | thanks dave |
Silver Member Username: Paul_ohstbucksPost Number: 745 Registered: Jan-05 | Sweet!! |
Bronze Member Username: Max190Maryland Heights, Missouri US Post Number: 34 Registered: Apr-05 | Joseph, Very nice setup dude. Thanks for sharing. Steve |
Bronze Member Username: Camaro823British Colu... Canada Post Number: 27 Registered: Jun-05 | Very nice man , looks like you put quite a bit of effort into it. |
Bronze Member Username: RsxmanPost Number: 21 Registered: Jul-05 | very clean..is that an Imac G5 u got there? If so i gots one too, they are neato |
New member Username: NathanpAtwood, IL USA Post Number: 1 Registered: Jul-05 | What are you using for connecting your DVD player,VCR, etc, to the receiver? Optical, HDMI, DVI, ANALOG or COAX? Im kind of a newbie at HT so please forgive me if I say a term wrong! lol |
Silver Member Username: Joe_cOakwood, Ga Post Number: 669 Registered: Mar-05 | dvd, hi-def cable, xbox and hi-def sat are connected to the tv via component(three rca type) connection. Dvdr and std def sat are connected via s-video. Sound is optical from dvd, sat , cable and xbox to receiver. I also changed the layout a little and added some stuff. https://www.ecoustics.com/electronics/forum/system-showcase/147420.html |
Bronze Member Username: Jb007The HagueEurope Post Number: 22 Registered: Jun-05 | This seup looks much neater Joseph. Sure you changed it for the better? nice place though! congrats! |
Silver Member Username: Disco_stanMinnesota Post Number: 182 Registered: Dec-03 | Yo Joe, what are your walls made out of...it looks like they are made of some kinda of acoustic material. |
New member Username: KenzpianoNJ Post Number: 1 Registered: Aug-05 | Joseph, what's the color of your wall paint ? do you recommend i paint my walls a dark color ? |
Silver Member Username: Joe_cAtlanta, GA Post Number: 948 Registered: Mar-05 | I painted my walls flat black and then covered them with black fabric, dyed burlap to be exact. Then nailed painted flat black crown and base mold on top with scribe at the fabric's seams. Works quite well. Not as good as proper room acoustic treatments, but a whole heck of alot cheaper. |
Silver Member Username: GamerdudeOntario Canada Post Number: 119 Registered: Apr-06 | i like the fish:D and its nice |
Bronze Member Username: Apresler07Canal Winchester, Ohio USA Post Number: 45 Registered: Jun-06 | That is a very nice setup. How much Did The whole electronics part of that cost? |
Silver Member Username: DelsolePost Number: 438 Registered: Feb-05 | joseph coulson that is incredible u really put some serious cash into that |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4832 Registered: Aug-05 | *jaw hits floor*....... |
Bronze Member Username: FuryousFL USA Post Number: 46 Registered: Aug-06 | Beautiful setup, dude. It's the best feeling when one of your systems finally comes together, especially when it is your dream system. Looks like you have a great space for a projector, too. Very low ambient light and dark colors. Would be cool to have a 150" screen for football games. |
Silver Member Username: GamerdudeOntario Canada Post Number: 159 Registered: Apr-06 | looks like its a couple hundred miles below ground it so dark!!! |
Silver Member Username: DarthThe woodlands Post Number: 101 Registered: Aug-05 | Joseph, Very nice indeed, congrats man |
Gold Member Username: Joe_cAtlanta, GA USA Post Number: 1476 Registered: Mar-05 | MISS THAT ROOM! Oh well, the gear I have now blows that stuff away - but it was really nice having a dark as you like dedicated room for listening and watching... |
