How to use optical output of dvd for 5.1 speakar system
how to use optical output of dvd for 5.1 speakar system
Username: Bomb
Rock Spring, GA USA
You should be able to connect the DVD player with your receiver, that is if you have a 5.1 channel receiver. Your receiver should have the input.
Username: Movie_collector
, California U.s
Post Number: 32
Your receiver should have "Optical" input and your DVD placyer should also have an input. If not, you will have to use analog.
Username: Illuminator
Post Number: 4989
lol, brad, you bumped a two year old post.
Need to Register?
Forgot Password?
Enable HTML code in message
