Yamaha RXV540 or DENON AVR 1803??
Guys I really need help to setup my very first "Tight Budget" Home Theatre systems.
I am interested in Yamaha RXV 540 or DENON 1803 which has good price, I will use it mainly for listening to music.
Anyone has opinion on those receivers. Or Any recomendation for budget receivers please welcome.
And I need to choose for the Home Theatre Speaker Systems, some of my friends recommend Infinity TSS 750.
Again Please help me on choosing this speaker systems.
Thank you so so much for the help.
Best Regards
Jimmy
Username: Elitefan1
Post Number: 90
How much do you have to spend on a receiver and speaker system?
jimmylh
elitefan,
I only have around $800 to spend for receiver and speaker.
Thanks
Username: Falp
Post Number: 11
Yamaha is olnly (very) good for movies.
Denon is very good for music and very good for movies.
Try a Marantz, is very good for movies and specially good for music.
Username: Elitefan1
Post Number: 104
Since your budget is so limited I would at least consider the Onkyo 501 refurbished from J&R Music World which can be had for $199.88. Comparable to the others you mentioned and will allow you to spend $600 or so on speakers.
