Mirage Omnisats with what NAD receiver
Wolvie
Im trying to determine if i should change to a Pioneer elite, NAD or what with my Mirage omnisats ($250) in a 20 x 13 room with an offset of 12 x 12. I currently have 6.1 onkyo 797. Will 7.1 be ok in these room dimensions and is it worth the change.
Username: Edison
Post Number: 223
I wouldn't - the onkyo is good - won awards as the best under 1k. In what ways do you want to better? Should be ok.
Perhaps better cables if you don't have already. www.accessories4less.com has ixos speaker cables (6003 is ok or upper models).
You might try experimenting with the placement of the speakers to get the best out of them.
