Subwoofers
Hi. I have a small space problem. I have only a little room for a stereo in the new bedroom and can only fit in a single deck sized stereo. The speakers will be as small as possible (MAX 100mm H)which will go almost to the ceiling above the wardrobes. My main problem is where to put the subwoofer. Does this have to be in an open area? Or could it go in a unit? If it has to go in the open would under the bed do it?
Plus does anyone know of a reasonably small subwoofer, say 200mm high and about 500mm wide? About the price range 150-200quid? Cheers for the advice in advance......Warren
i think you are going to have to look at a bose lifestyle system for speakers that smalle
