Rotel RSP1098 vs Marantz SR7300 (Both Using CS49400)
ISS
I realise that both are using the same Cirrus Logic CS49400 processor.
Does this means that the SR7300 has the same sonic capabilities as the RSP1098 when it comes to movies?
Username: Edison
Post Number: 220
No - other parts are different so you will get a different sound. Go with the one that sounds better - I like Rotel.
