New member Username: FlagerrPost Number: 4 Registered: 12-2003 | I Wonder which one better paired with my NAD T760, Wharfedale Diamond 8.3 floorstanding type or JBL in the same class (sorry I forgot the type). Anyone has better suggestion ? thx a lot ![]() |
New member Username: EdisonPost Number: 211 Registered: 12-2003 | Diamond is better. These are as good if not better. http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AMB S667 CBM-170 ascend acoustics: http://www.ascendacoustics.com/Main/Intro/Firstpage.asp They both sell direct, cutting out the middleman, to give more for the buck. They also got great reviews - you can read them on the sight. You can try them out and return them if you are not satified. Home is the ideal place to try speakers - with your components, and in your room (acoustics), with your favorite music. www.axiomaudio.com - for reviews. The other sight is cheaper though. |
