New member Username: BradenPost Number: 2 Registered: Sep-04 | Need a complete HT system with a budget of about $1800.00 I have been researching for weeks now and I have the itch to get the HT that will rock my house, Room Size: 45 long 8 high 15 wide TV is 65in HDTV and main seating area is about 15-18 ft from tv. Open space behind seating area, cannot be closed off.. 95% HT 5% Music... Was recommended the following.. Receiver: Yamaha 5760/Yamaha RX-V650/HK/DENON?? any suggestions Sub: HSU VTF-3 MK2 or STF-3 maybe SVS?? Speakers:JBL/Axioms/Ascends/Swans/Klispch?? Do not know? Is it ok to mix and match?? Need specifics since I am a newbie!!!!! Going to go 5.1 for now but want to be able to upgrade later to 7.1 |
Gold Member Username: Project6Post Number: 1394 Registered: Dec-03 | I thought I answered this yesterday? Anyway try this out...one of the best I've heard http://www.ascendacoustics.com/index.html they are also having a sale on HK electronics so check it out. use their HT system builder. cheers |
New member Username: Peter_duminyVancouver, B.C. Canada Post Number: 1 Registered: Sep-04 | Have you tried the B&W 600 Series by chance? Great sound - good price. Paradigm is another fine choice too. |
Bronze Member Username: BleustarPensacola, Florida Post Number: 61 Registered: Jul-04 | I think there are choices better than the Yamaha HTR5760 if your budget is $1800. Harman Kardon's AVR230, 330 or 430 would be a good place to start. Or maybe the Marantz 5400. That is $400 -$700. Then a good dvd player $150-$300 and the rest for speakers. HK's dvd22 is $200 and is highly rated but has no DVD audio or SACD. There are many speakers that will sound great for the budget you have. Make sure the speakers are matched properly. Happy listening! |
