Paradigm monitor 7v3 or klipsch RF15
Which one should be the best match for an HK 630 receiver?
Username: Project6
Post Number: 1363
Have you listened to any of them?
henrique
Berny,
Unforntuntely I've not listened to any. Actually I will buy based on opinions because where I live there is not a single store with these models. I've listened just the paradigm studio 60 but it is much more expensive. I could say that the usage will be 50% music and 50% ht and I listen to rock/pop and jazz mostly.
Thanks for any help.
henrique
Berny,
Unfortunately I've not listened to any. Actually I will buy based on opinions because where I live there is not a single store with these models. I've listened just the paradigm studio 60 but it is much more expensive. I could say that the usage will be 50% music and 50% ht and I listen to rock/pop and jazz mostly.
Username: Project6
Post Number: 1379
I liked the way any Klipsch RF series sounds on HK and I think they would match well together.
