Klipsch RB15 vs Paradigm Titan vs Mission MS31MB
Username: Vgtvidz
It says it all, I wondering which set of speakers I should between these 3... Please note that I currently own a Yamaha RX-V350S receiver and a Klipsch RW-8 subwoofer... so yeah, I'm waiting for your recommandations, thanks!
Username: Shank
Pittsburgh, PA
Post Number: 58
Fi you have a yamaha receiver, your prolly don't want to get the klipsch bookshelf speakers.
Username: Vgtvidz
why not?
Username: Vgtvidz
Why not?
Username: Vgtvidz
Oups sorry for the 2 replies
Username: Shank
Pittsburgh, PA
Post Number: 59
I think yamaha recievers are usually bright, and klipsch speakers are bright as well. So together, they may sound a bit shrill.
I'm not a klispch basher, as my main speakers are rf-25's.
I'm just suggesting not get get a klispch speakers with the yamaha based on what others on the forum have said.
Username: Vgtvidz
Thanks man, I might check for the Paradigm speakers then
Username: Project6
Post Number: 1343
Paradigms are a great choice for your Yamahas.
