New member Username: HdaveearlPost Number: 8 Registered: 12-2003 | I bought the Energy Take 5.2 speaker system with the S8.2 Sub Woofer. The back has 2 connections one says Input and the other Xover. From reading the instructions I get the impression I should connect my receiver to the Input. But I've read else were that that its better to connect to the Xover which it says allows the receiver to control the Sub woofer instead of using the Subs independent controls. Any Advice you can give me would be appreciated. If it matters I have a NAD 742. I currently have it connected to the Input but don't want to accidently hurt something by hooking it up wrong. Thanks |
Anonymous | This might help:- http://www.audiorevolution.com/equip/energy/ |
