cdburner Unregistered guest | I'm recording from vinyl and tape to my computer through a SB Live card and Cakewalk. The signal also goes through a Mackie mixer which allows me to boost the level if necessary. The record levels are set right, I believe, just under clipping. The end product sounds fine enough except it seems the output level is a little low compared to commercial cd's. What can I do to level the levels without clipping or distortion? Thanks! |
Unregistered guest | I got a philips cdr930 mimi cd recorder.After a power surge it could not switch on.Anybody with a copy of its power supply schematic diagram? Pliz help! |
Unregistered guest | I got a philips cdr930 mimi cd recorder.After a power surge it could not switch on.Anybody with a copy of its power supply schematic diagram? Pliz help! MY E-MAIL: bwtikh@yahoo.co.uk |
