New member Username: Kawi007Post Number: 1 Registered: Aug-04 | please help if you know of anyway they can be hooked up to my tv. there has to be some sort of way i can get my tv sound out of them. thanks a million for your intelligence! |
Silver Member Username: LandrovalPost Number: 570 Registered: Feb-04 | Yes they can. Just plug a wire between tv audio output and the green jack at the decoder unit. Probably you need a 2xRCA->3,5mm miniplug wire. http://www.bit-tech.net/images/review/266/z680_018.jpg |
Silver Member Username: EdisonGlendale, CA US Post Number: 547 Registered: Dec-03 | Radioshack has the cable you need - explain what you want to do, or write "double RCA to 3.5 male miniplug wire", and you are all set. |
