Amps
Username: Ass
i bought a pair of collins fl215 loudspeakers wich are 350w would i buy a 350w per channel or 350w all together
Username: Thugboy2005
Greensboro, Nc North A
i got a burik park ave and im trying to hook up a poinar cd player and a amp i got 1 speaker working but the orthers wont come on whats the promble
Username: Kegger
MICHIGAN
Post Number: 1390
(joshua watts) being a pa speaker they handle a lot of power "that is the 350" rating.
they are a 4ohm speaker so make sure the amp can
handle a 4ohm load.
I can not find a sensativity rating on the speaker. but 200watts per
channel at 4ohm, 2 channel amp should be fine!
Username: Kegger
MICHIGAN
Post Number: 1391
(tony andrews) you need to try the car audio section this his home audio!
