Technical question - Power ratings on the Arcam AVR300
Audiofreak
Listed on the technical specs with regards to the Arcam AVR300.
"Meets rated 100 WPC continous power output into both 4 and 8 ohms, all 7 channels driven simultaneously at 1khz"
"Stereo output power over 120WPC into 4 or 8 ohms, 20hz-20khz"
Some amateur questions.....
a). Wouldn't measuments at 20hz - 20khz be more accurate compared to 1hz?
b). If that is the case, can the Arcam still deliver deliver 100watts x 7channels continously?
c). Why do they measure 7channels at 1hz and stereo at 20hz-20khz?
Could someone shed some light on this subject?
