Car Audio to Home Audio.... How???
I was wondering how one would go about transferring some car audio to home audio use. For example, I'm one of many college students who have had to take out their systems in their car for fear of getting it ripped off. Could someone explain to me the required materials/components needed to transfer these speakers/ subwoofers over for home audio use. Thanks in advance for any replies...
Garrett
Username: Project6
Post Number: 1239
check out this thread
https://www.ecoustics.com/electronics/forum/home-audio/2783.html
lots of info
Yeah... I just spent about 20 mins reading most of that and if I could just get an answer for my specific situation. I have 2 Dual 2ohm Kicker S12's and a JBL 1200.1 Mono amp. I was wondering what kinda AC-DC converter I would need along with everything else. Any further information especially that pertaining mainly to my situation would be greatly appreciated.
Thanks,
Garrett
Username: Kegger
MICHIGAN
Post Number: 1380
well you would need to read the specs on the amp, as far as wattage
draw then get get a power supply that can handle that.
a good power supply to give you the proper wattage can be very pricey.
a wall mount unit just doesn't cut it.
i think partsexpress.com carries them. or ask in
the forum section over there.
