42" Akai and 42" Samsung Rear projection TVs and Fixed audio out
Do the Akai 42" HDTV rear projection TVs or the Samsung 42" HDTV rear projection TVs have a fixed audio out for hooking up a home theater system? Can you turn the speakers completely off and run them through you home theater receiver and hook it up to a hdtv digital cable box? I have been thinking about getting an Akai 42" or Samsung 42" for our den but the guy at CC said you could not do what I asked above with the Akai. I am very curious about both.
I would appreciate any answers you can give me.
Thanks
MarcUR
the guy at CC doesn't know how to set up a home theater. If you have a cable box, all you do is send the video feed to TV and the audio feed to the receiver. No need to send any audio to the TV and then back out to the receiver. Now if you didn't have a cable box, but rather basic cable with coaxial cable that connects directly to your TV, you might have a problem, but since that isn't the case don't worry about it.
