Is there a dealer that doing exchange
Daniel Benatar
Is there a dealer that doing exchange to used receiver NAD to new one NAD and or different firm such Rotel and ARCAM? I am moving to Europe and wanted to have a to exchange mine NAD T773 110volt to 220volt receiver.
Thanks, Daniel
Username: Edison
Glendale, CA US
Post Number: 534
You can keep yours and get a electric converter - pretty cheap.
Username: Geekboy
Newport, RI United States
Post Number: 352
Daniel: if you get a converter, as James wrote, make sure you get one rated for the wattage that your receiver needs! I would say, make sure it exceeds it! If your receiver draws 1000W, get a 1500W converter! I've used the converters and all of the ones I've used have always reset themselves when under stress (high wattage/current draw. You cannot use a 50W "shaver" converter!
