Can I setup yamaha rx-v2400 for 6.1 system?
Username: Jhopper
Big Spring, TX USA
I currently have a 6.1 system, but plan on upgrading to 7.1 soon. If I went ahead and purchased the yamaha rx-v2400 receiver could I set it up to operate my 6.1 speakers?
Username: Landroval
Post Number: 536
Yes
Sarandon
just make sure you go into the receiver's speaker setup menu and say that you only have 6 speakers instead of 7 speakers, And make sure you put your rear center channel in the left surround back speaker terminal. You can also read the owner's manual and it will tell you the same thing.
they're on sale for 40% off at GG (if ya can find'em) from yday till 9/7
