RRL9 Unregistered guest | Hi all, Does anyone know of a decent quality but small sized CD player. My problem is that I don't have the space for the "typically" sized CD player (usually it's around 17" x 15" x 4"). I recall seeing some nice players (somewhere?) that are about the size of a small shoebox. I know MBL and Audionote make some small players, but these are about 17K $. I'm looking for something more in the price range of about 200 up to 1000$ (preferably on the lower end of that range). thanks, rich |
Silver Member Username: EdisonGlendale, CA US Post Number: 532 Registered: Dec-03 | Musical Fidelity makes one I think, and Quad also, although may cost more than you want to spend - the quad. |
New member Username: AntmanCape Town, Western Cape South Africa Post Number: 4 Registered: Aug-04 | Hi You might have a look at the Cyrus CD6, I think it is around $800. Been a large award winner in Europe. Anthony |
Bronze Member Username: Bobby29Post Number: 43 Registered: Apr-04 | Quad |
EMC Unregistered guest | Linn Mimik or Genki. |
Silver Member Username: Ca_convertCardiffUK Post Number: 150 Registered: Jan-05 | The Cyrus CD6x or CD8x are smaller that yer average bear. Both are allegedly fine sounding machines. |
Slaphappy Unregistered guest | I have the same problem, no room for a big system, and not a very big budget. I was thinking about getting a Car Indash player and building a box for it, but I am not sure about how to go about installing it. |
Silver Member Username: TevoChicago, IL USA Post Number: 134 Registered: Feb-05 | Musical Fidelity X-RAY V3 CD http://www.musicalfidelity.com/mf/en/Products/XSeries/XRAYV3 |
