New member Username: Me_is
Post Number: 1 Registered: Aug-04
Posted on I am looking at a pair of SDAT: MS-E800 speakers and they are 4 ohms. all my other speakers are 8 ohms. the amp i am using is a old marantz model 1030 |
Gold Member Username: Kegger
MICHIGAN
Post Number: 1323 Registered: Dec-03
Posted on most of your older marantz handled 4 ohm loads with no problem. but i would try and find the manual or something online to verify. maybe even call marantz or email. |
Post Number: 3 Registered: Aug-04
Posted on is it harder to handle 4 ohms than 8 ohms?
MICHIGAN
Post Number: 1324 Registered: Dec-03
Posted on yes the lower ohms are harder on the amp. some can handle a 4ohm even a 2ohm load. but others will burn up with anything lower than 8. |
Post Number: 4 Registered: Aug-04
Posted on k thanks man |
Post Number: 5 Registered: Aug-04
Posted on oh and what would i look for in the specs that would tell me if it could handle speakers with 4 ohms |
MICHIGAN
Post Number: 1325 Registered: Dec-03
Posted on basically the specs would say something like this. 85watts per channel at 8 ohms. 150watts per cannel at 4 ohms. or in the manual it will say minimum impedance is (x). |
Post Number: 6 Registered: Aug-04
Posted on don't got the manual all i got is this RMS Power Per Channel 15
MICHIGAN
Post Number: 1326 Registered: Dec-03
Posted on yah that doesn't tell you anything! sometimes if you look closely on the back of the unit it may give speaker impeadence. other then that you need to do some research. |
Post Number: 7 Registered: Aug-04
Posted on ive been trying but its hard as hell 2 find info on old amps |
