Bose & Yamaha --- Help Needed
Username: Postvenki
Peoria, IL United States
Hi All
I have purchased Bose Accoustimass 6 Series II.
Can you tell me whether this is a gud HT spkrs.
What receiver do i need to buy to go this spkrs.
I don't have any idea on this.
I got this Bose Spkrs from SamsClub for $350.... and i don't know whether thy r gud also.
So plsssssss help me out in Findin gud receivers around 300$.
thanks for u guys help
Venki
ABC
try jandr.com
Username: Kegger
MICHIGAN
Post Number: 1321
any reciever from marrantz/pioneer elite or h/k
are good recievers.
the bose speakers are nothing great.
Username: Pit
These speakers are not outstanding but do not judge soooo hard KEGGER. I think the bose speakers do a good job with a cheap receiver which has a digital output. So the sound weakness of the amp can be evaded. But sound wise you would not get any added value with an amp upgrade in the future.
Username: Landroval
Post Number: 533
I just heard a quite expensive Bose set at a dealer, and it was just as bad as I remembered. There's really no reason to defend the Boses. Even Creative Gigaworks computer speakers will outperform Bose systems, and they're much cheaper and about the same size.
