Next to Buy: Sub, DVD Player, Or Surrounds
Username: Sgtpeper
Post Number: 10
As some of you know I have the following setup so far: PE 45tx, Monitor Audio S8 fronts Silver center 12i center (which I did go to saturday audio while im home and compare to the SLCR and my 12i sounds as good if not better)
Currently I have some old JBL sub and Im using some old yamaha bookshelf speakers for surrounds. AND sadly for a DVD player I am currently still using my PS2 hooked up through component and optical connections.
My question is, what would you get next? DVD player, sub or surrounds, and which would you get? Im not really sure which I should get.
Thanks
Jeff
Username: Kegger
Post Number: 22
i personally would get a new dvd player.
maybe with progressive scan, maybe sacd, maybe dvd audio it will also give you a coax digital output.
i don't really have a suggestion on a dvd player
stick with a name brand that has the features you
want.
Username: Sgtpeper
Post Number: 11
Anyone? Please :-)
