I cannot get to my System Setup screen on my Denon AVR-3300. I've connected my S-Video connection from my TV to the Denon on both the Monitor and TV/DBS connections. When I press the System Setup button I still get no Setup on the TV. Any suggestions on how I can to that screen?
Also, I have a Pioneer 810-HS (tivo/dvd burner device) that I've connected to the Denon using a Digital Optical cable. The Denon recognizes the connection between the two (the denon says the signal is locked) but I get no sound from the Denon. The cable is hooked-up to the Opt 1 and the default for the DVD is Opt 1 on the Denon. Might you know why no sound is coming out? I've choosen the correct setting on the Pioneer to recognize the Digital Optical cable as default audio option.
